Speedo cable
Old Mar 6, 2023 | 02:02 AM
Jimmy nz's Avatar
Jimmy nz
Speedo cable
Hi all,ive replaced the manual transmission in my 66 with a c6,the c6 has a different speedo cable lnput than the manual trans its also on the other side.the origonal cable is too short,what cable should i get to replace it
Old Mar 6, 2023 | 08:06 AM
Grampa69's Avatar
Grampa69
I don't know if this will trigger any ideas but I used to replace accelerator cables on old cars with motorcycle cables. An MGB I had needed a cable quickly and I used a bicycle brake cable.
my mistake.. I was thinking accelerator cables not speedometer cable.
Last edited by Grampa69; Mar 6, 2023 at 02:43 PM. Reason: Sorry. Speedo not accelerator
Old Mar 6, 2023 | 08:43 AM
Crop Duster's Avatar
Crop Duster
Those cables are readily available from Carpenter, NPD etc. and even the parts houses. Just look for one for a truck F100/250/350, 1968-1972 with a C6 transmission.
Don't forget to get the correct speedo gear for your rear end ratio and tire diameter while you are at it.
Old Mar 6, 2023 | 10:05 AM
Sortofa65's Avatar
Sortofa65
Yes, I have a 70' c6 in a 65' F250 I've ordered the cable for a 70' from Napa and it fits fine I believe it's 82-83 inches long. If your speedometer is off I don't know where you can fimd the gear for that c6 I haven't been able to locate any.
Old Mar 6, 2023 | 12:29 PM
Crop Duster
If your speedometer is off, I don't know where you can find the gear for that c6 I haven't been able to locate any.
You can get those gears at your local Ford dealer or NPD, Carpenter. If you need a 21 tooth this is one of the few places that have them.
Ford Automatic Transmission Speedometer Driven Gears (transmissioncenter.net)
Old Mar 6, 2023 | 02:52 PM
Sortofa65's Avatar
Sortofa65
My c6 has a metal gear and shaft, The end of the shaft is a square hole where the end of the cable goes into. It doesn't look anything like advertised speedo gears
Old Mar 6, 2023 | 11:22 PM
Jimmy nz's Avatar
Jimmy nz
Mine is the same metal shaft and drive it appears that lmc may have the right cable for 9.95 but with $70 freight $14 tax on top i would like to be sure its the right cable.that equals about $170 in our currency
Old Mar 7, 2023 | 04:38 AM
Crop Duster
I see now you have the short cast iron tail housing. Good luck finding parts for that. Ford only used that for a few years like 68-70. You can try an advanced search using Number Dummy as the username. I'm sure he posted part numbers for those parts in the past.
Old Mar 7, 2023 | 07:33 AM
Sortofa65's Avatar
Sortofa65
I've ordered the cable from both Rock Auto and Napa. Rock is a pioneer brand and I don't remember what Napa was. Napa brand seemed a bit better made and was about $30. Napa is part# BK6151606 and is 87 inches long for a 1970 F250. Both brand cables fit fine but one was ruined by melting the casing on the exhaust. I don't know where you live but these cables can't weigh much more than a pound for shipping purposes. Both my column and trans came out of a 70' and as Crop Duster said this is the short tail c6 made for use with the two piece driveshaft.
Old Mar 7, 2023 | 09:56 AM
Crop Duster
I was referring to the drive and driven gears more than the cable as being hard to find. Here is a thread to read thru. It's old and who knows if any of the parts ND posted are still out there. But short of switching to a later aluminum tail housing that uses the nylon gears this is it.
Speedometer gears - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Mar 7, 2023 | 05:33 PM
Sortofa65's Avatar
Sortofa65
CD I know what you meant about the gear what I was wondering about is how LMC would want $70 to ship a cable
Old Mar 7, 2023 | 09:09 PM
SwampRattFord's Avatar
SwampRattFord
I think the OP is in New Zealand.
Old Mar 8, 2023 | 01:48 AM
Jimmy nz's Avatar
Jimmy nz
Thanks for the help ,im going to get a cable made here in nz ,freight charges have gone crazy since covid
Eharang
Apr 2, 2020 05:31 PM
coppertales
Oct 6, 2015 10:49 AM
midsouth
Oct 8, 2011 12:33 PM
Nathan
Apr 30, 2001 03:40 PM
Fatz
Mar 31, 2001 06:55 AM
