2012 F150 AC Mode Issue
Old Mar 5, 2023 | 07:32 PM
jasonkmayo's Avatar
jasonkmayo
1st Gear
Hey folks,
I have a 2012 F150 with about 130k miles. I’m having issues with my AC mode selector in my truck. It’s stuck blowing air out of the defrost/foot vents and can’t be changed to front vents.
I assumed it was the actuator, so I took out the old and replaced with a new one. Before fully installing, I just hooked up the electrical connector to verify that the new one worked properly. The first time I tested it the actuator gear moved when I pushed the mode button, so I assume the new actuator isn’t a problem.
I manually turned the gears attached to the vent doors and it moved without issue. So I don’t think that’s a problem either.
After further button pushing, the actuator gear would only move when the defrost/foot mode was selected. But not on every cycle. It appeared random. This leads me to believe the issue is electrical. Has anyone had a similar experience? Were you able to resolve it?
Regards,
Jason
Old Mar 12, 2023 | 06:14 AM
JWA's Avatar
JWA
Not sure this will help but maybe check it over to see if it might? https://www.ford-trucks.com/forums/1...-controls.html
stephkimb
Jan 17, 2023 12:07 PM
basssdrop
Jul 12, 2022 04:51 PM
eriebasin
2021+ F150
Sep 26, 2021 04:30 PM
ZCarr
2009 - 2014 F150
Oct 19, 2020 05:02 PM
smelter
2004 - 2008 F150
Apr 10, 2008 09:17 PM
