I have a 2009 F150 Supercrew and I am having problems with the climate control. The temperature selection **** does not match the output form the vents, the AC works and I know where to set the dial in the hot range to make the air blow cool but I would like to fix this. The Max AC button will not work either, has anyone else had this problem and if so what was the resolution.
