5 speed OD transmission ID help needed
I pulled this 5 speed OD off a 292 Y block from a 1960 F600. Was told the motor was swapped at some point. It has a Spicer PTO gearbox. The only tag on it tells me nothing that I can make sense of. Is this a Clark or New Proccess transmission and what model? Thank you.
The following users liked this post:
Looking at the shop manual I would say it looks like a 5-Speed Medium Duty Clark. The three nubs on the cover behind the shift lever are a clue. The heavy duty only has two of those nubs and the extra heavy duty cover looks altogether different. If you don't have a shop manual, I would highly recommend one. They have a lot of info you would be interested in.
By the way, that sure cleaned up nice! Even got a starter!
The link in this thread shows the case number, 224716, as being used for several Clark 5 speeds, direct and over. The pertinent info does not copy and paste well. Scroll down to page 3 and look to the right of center for "CASE". You will find your number and the associated transmission models to the left.
http://www.roadranger.com/ecm/groups..._apmt-0069.pdf
I can move you to Large Truck if need be or if you want.
Brad Brown
03-27-2022 12:19 PM
NOID4RP
05-16-2021 04:31 PM
tigger4u44
17
01-11-2021 06:19 PM
iwanaflattie
02-13-2020 10:29 PM
