Sponsored by: Real Truck
electrical problem, any ideas?
Old Nov 15, 2003 | 07:18 PM
engine9's Avatar
engine9
I have an electrical problem I can not fiqure out. I have a 2000 F250 superduty. It started with the blinkers not working at all, then went to only the right blinker working. Now I have no blinkers, hazards or brake lights. The parking and headlights work fine. Havn't added any new electrical or trailer lights. All the bulbs and fuses are fine. If it was shorting out somwhere wouldn't the fuse blow? If you have any clue please post. Thanks.
Old Nov 15, 2003 | 08:30 PM
99f350sd's Avatar
99f350sd
everything goes through the multi function sw ie turn signal sw.
Sounds like it bailed out bigtime.
Old Nov 16, 2003 | 02:25 PM
engine9's Avatar
engine9
Thanks for the response, I will give it a try
Old Nov 17, 2003 | 02:03 PM
engine9's Avatar
engine9
99f350sd, you called it right, it was the multi function switch. Thanks again
Old Nov 17, 2003 | 03:46 PM
99f350sd's Avatar
99f350sd
Thanks for letting us know the outcome..
Old Nov 24, 2003 | 12:50 PM
mgar's Avatar
mgar
I am having the same problem on my 95 F150, where is theis switch you speak of? Where can I get a ne one?
Thanks!
Old Nov 24, 2003 | 01:05 PM
Hjudge49's Avatar
Hjudge49
It's attached to the lever on the left side of the steering column that you move to turn on the turn signals, etc. It isn't a do-it- yourself fix unless you have a steering wheel puller. All the power for the turn signals and brake lights run thru the switch, that's how come the turn signals flash when the brake lights are on.
rossseger
Nov 3, 2014 02:09 PM
will32_
24
Sep 28, 2014 10:18 PM
ooxneozoo
Jun 22, 2014 08:25 AM
Kouwenberg7.3
Apr 26, 2014 06:04 PM
marks69
15
Feb 20, 2010 11:22 AM
