Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Cab swap
Old Mar 1, 2023 | 09:25 AM
BadRadDad's Avatar
BadRadDad
Cab swap
So I have a F600 with a single cab. I want to put a bed on the truck but the 84” cab to axle means lengthen the bed or shorten the driveshaft and move the axle. Then a third option popped up. What about swapping a single cab for an extended cab? What’s the cab difference on an 80’s model single cab vs extended cab? 24” would be ideal.
Old Mar 1, 2023 | 11:49 AM
BadRadDad's Avatar
BadRadDad
Looks like I might be in luck. The wheel base between a single cab and super cab is 22" It might be just what I need. Now to find the donor truck and check NV regulations on cab (VIN) swaps.
Old Mar 1, 2023 | 07:49 PM
Mattrl1985's Avatar
Mattrl1985
Another thing to consider is the f-600+ had a different floor and firewall configuration than that of the pickup trucks. The transmission “tunnel” is higher in the pickups than the large truck, shouldn't be a problem if your 600 is a gas. Diesel’s in the large trucks have a flat floor and removable doghouse in the firewall so a pickup cab might not fit to a diesel large truck without modifications. The extra length of the wheelbase will reward you with a better ride but to me it would be less work to shorten the wheelbase then to change cabs. With some careful measurements and sharp drill bits you can get the perches moved in an afternoon. I have done several with just a slow turning 1/2” drill and cutting oil, you don’t need a mag drill, Then measure and have your drive shaft professionally shortened for less than what a good extended cab would cost. My 2 cents, good luck!
Old Mar 4, 2023 | 09:53 AM
BadRadDad's Avatar
BadRadDad
Thanks, I think I’ve settled on having a body shop graft two beds together. I can still drive the truck while the body shop puts the beds together.
Old Mar 4, 2023 | 09:57 AM
BadRadDad's Avatar
BadRadDad
FYI for anyone wondering what cab lengths are I measured from front of the doors on all three cabs to the back wall
single 48”
super 72”
crew 84”
i ran all around town looking for trucks.
A single cab right now I have 84” cab to axle.
with the super I would have been at 60”
crew cab 48”
closest was the super cab but I would have had a 4” gap to fill.
bert cook
Mar 4, 2014 10:15 AM
Builtihtuff
Jun 3, 2011 07:51 AM
bullrider100808
Apr 25, 2011 04:00 PM
Fordenthusiasts
Feb 21, 2008 09:20 PM
zhigaag
Mar 6, 2006 04:26 PM
