Cab swap
Old Jun 1, 2011 | 06:25 AM
Builtihtuff's Avatar
Builtihtuff
Cab swap
I have a 1990 ford f250 single cab long bed
But I want to remove the single cab and long bed and put on a 1997 f250 crew cab does anyone know if it will fit and if it does how long would the flat deck behind it be ?
And would I have to use the bin from the old swap or new cab
Old Jun 1, 2011 | 06:43 AM
cj06's Avatar
cj06
it would work but you will need to fab up your rear cab mounts , THE FLAT DECK as in bed ? I think the crew cab is around 2.5' longer than a regular cab !
Old Jun 1, 2011 | 07:09 AM
Builtihtuff
So how much space will I have I don't know the over all length of the crew cab from the fire wall to the rear wall of the cab also how would I fab up some cab mounts this will be my first build I want it done right
Old Jun 1, 2011 | 04:55 PM
tjc transport's Avatar
tjc transport
i ain't rite
this will also be an electrical nightmare, cause the electrical will be all different
Old Jun 1, 2011 | 05:59 PM
Builtihtuff
Can u be a little more detailed on what u mean ?
Old Jun 2, 2011 | 04:01 AM
tjc transport
i ain't rite
90 dash is mechanical speedometer, 97 is electronic.
the wiring harness will be completly different between the two cabs.
90 also uses a long steering column, 97 uses a short column.
Old Jun 2, 2011 | 06:18 AM
Builtihtuff
I think the only issue would be the steering column I'm doing an engine swap so the dash will need to be replaced anyways and I'm looking at a 86-97 crew cab I know different model years maybe I should steer twords older ? If possible what do u suggest ?
Old Jun 3, 2011 | 07:51 AM
tjc transport
i ain't rite
87 to 91 gas engine wiring harness will be the same, and then 87 to 91 diesel will be the same. gas and diesel wiring harness is different.
special_k
Oct 8, 2013 01:56 PM
Builtihtuff
Paint & Bodywork
Jun 1, 2011 09:16 AM
DILLIGAF13
Offroad & 4x4
Jun 17, 2009 11:09 AM
catan70
Mar 6, 2008 09:49 PM
mositso
May 11, 2004 10:55 PM
