here's a crazy question!!!
Old Feb 27, 2023 | 11:08 PM
carl2591's Avatar
carl2591
So wondering if it possible to change out standard rear diff for Limited slip on 2003 250.. or do you have to replace the whole rear axle with LS.. ?? I know i can replace with a locker, but lockers are not good in snow, ice and a limited slip is.. locker is probably better in sand, mud etc
if so any idea on cost?? where to do this? Person/ shop etc.. we located in FL till April then Central NC area..
Old Feb 27, 2023 | 11:15 PM
Tpayne621's Avatar
Tpayne621
Yes you most certainly can. Any reputable offroad/drive train shop should be able to handle it for you. When you get back to NC look up east coast gear supply. They can do it for sure.
Old Feb 27, 2023 | 11:51 PM
carl2591's Avatar
carl2591
they on hwy 401 north of Rolesville?? anyone you know there to recommend? thanks
Old Feb 28, 2023 | 02:19 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Go all the way buddy!
Old Feb 28, 2023 | 04:24 AM
callforfire's Avatar
callforfire
I second going truetrac.
Old Feb 28, 2023 | 07:10 AM
Dan V's Avatar
Dan V
If I go in after mine...it's getting a TrueTrac.
Old Feb 28, 2023 | 07:40 AM
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by aawlberninf350
^^^This. Definitely this. It transformed the way my truck drove in slippery conditions completely.
Also, if you believe what Gale Banks has to say about square-back high-volume diff covers, ditch that Mag-Hytec and go with the finned aluminum cover from an '08 and up axle (assuming you have a Sterling).
Old Feb 28, 2023 | 08:00 AM
Tpayne621's Avatar
Tpayne621
Yep that's it. I've never personally dealt with them but there highly reccomended in the area for 4x4 drive train work. I've been 4 wheeling for 15 years and you still see there name highly reccomended.
Old Feb 28, 2023 | 02:48 PM
ezlivin11's Avatar
ezlivin11
Doesn't matter Open, locker, LS, or truetrack carriers as long as it is of like size (8.8, 9, 9.5 ect.) the will all fit in the rear diff housing. I changed the 8.8 open carrier w/3.23's in my crown vic to a 3.55 LS no issues other than the speedo calibration. Rember if the carrier is used (or any internal part) it must be re-installed exactly as it was in the doner vehicle or it WILL start making noise, especially the ring and pinion. wear patterns must match in order to have any chance of a quiet rear end. For this reason most diy'ers swap the complete differential not just gears.
Old Feb 28, 2023 | 07:01 PM
m j's Avatar
m j
Lockers are awesome in snow and ice. limited slip suck in snow and ice
Old Feb 28, 2023 | 07:38 PM
97-psd's Avatar
97-psd
As a consideration, I swapped my open diff carrier to a factory LSD. I used my original ring gear and, to my benefit, the shims were exactly the same the two axles. This allowed me to upgrade to the LSD without any significant work. It has been rolling around for about 40-50k without any problems. Depending on your goal and budget, there are multiple options.
I also second the 08+ diff cover. It looks good and is functional.
RA112222
1997 - 2003 F150
Jan 19, 2009 09:10 PM
GeneStoner
Jan 20, 2005 11:21 PM
ASE
Sep 2, 2004 04:19 AM
jubrown
1983 - 2012 Ranger & B-Series
Dec 7, 2003 06:50 PM
Petiboy
1997 - 2003 F150
Aug 16, 2003 12:01 AM
