Bleeding brake system
Old Feb 27, 2023 | 02:09 PM
Anonymous12's Avatar
Anonymous12
I have a 88 f-150. It has rear ABS. And I was seeing a thread recently posted about a RABS bleeder tool. I need to replace the brake booster and master cylinder. Am I gonna have to separately bleed the RABS module? I’m gonna flush the system too. Will it work going Right rear, left rear, right front, left front to bleed it?
Old Feb 27, 2023 | 02:14 PM
jas88's Avatar
jas88
I never have.
Old Feb 27, 2023 | 02:36 PM
sandymane's Avatar
sandymane
Your sequence is correct.
Old Feb 27, 2023 | 02:39 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Bleed the electric module? No
The order is : right rear, left rear, hydraulic control unit, right front and last bleed the left front brake.
Old Feb 27, 2023 | 03:35 PM
yeet's Avatar
yeet
hydraulic control unit, ^^^^^^From post above^^^^^
Can you elaborate on that? What is the Hydraulic control unit?
Old Feb 27, 2023 | 03:54 PM
My4Fordtrucks
The part on the frame rail by the fuel filter.
Old Feb 27, 2023 | 05:09 PM
yeet's Avatar
yeet
Ahhhh...OK. I'm a recovering GM/Chevy addict. We called that the proportioning valve over on the dark side.
Old Feb 27, 2023 | 05:42 PM
My4Fordtrucks
That is not a proportioning valve. Only the rear brake lines run through it. There is a solenoid inside that is electrically controlled by the RABS module.
Old Mar 28, 2023 | 08:44 PM
Anonymous12
AMSOIL sells 12oz bottles, how many will I need to completely flush the system?
Old Mar 29, 2023 | 12:48 AM
Prototypemech's Avatar
Prototypemech
I go through a quart (32oz) pretty quickly bleeding brakes.
Old Mar 29, 2023 | 11:09 AM
IsaacCarlson's Avatar
IsaacCarlson
I removed my rabs module. It wasn't working and I don't really like abs, so I tossed it. Easy brake bleeding and less to worry about.
Old Mar 29, 2023 | 02:46 PM
Mo8414's Avatar
Mo8414
I did the same thing just made a break line to route around it. Breaks work just fine without it
our_corky_rv
Nov 26, 2021 09:26 PM
dpoc
1983 - 2012 Ranger & B-Series
15
Nov 18, 2020 04:55 PM
crazyrwe
Escape & Escape Hybrid
Jan 9, 2013 07:05 AM
preppypyro
1997 - 2003 F150
Jan 23, 2006 09:01 AM
tadslc
Apr 30, 2003 09:55 PM
