1992 E-350 brake system
Old Nov 25, 2021 | 05:53 AM
our_corky_rv's Avatar
our_corky_rv
Hi, I need some help. I change rear cylinders and shoes. Front calipers and pads, also power brake booster. I bleed every point of bleeding have a solid pedal no sinking but once rv is turn on it goes a bit more than half way down I have brake but don’t seem to be right, so I don’t know if I have to adjust the shoes adjusters or if still air on lines. Thanks for any suggestions.
Old Nov 25, 2021 | 09:10 AM
tabijan's Avatar
tabijan
I’m guessing a ‘92 doesn’t have ABS.
Did you bleed or prime the master cylinder? That can be a tricky job on a compound master cylinder that has a spring between the front and back pistons. Tipping the front end of the master cylinder downward while bleeding might help. Check YouTube for ideas. Pressure bleeding is the way to go if you have a setup for it.
Sixto
07 E350 5.4 176K miles
Old Nov 25, 2021 | 09:33 AM
our_corky_rv
It have rear abs and I did bleed the abs not the cylinder what sequence I should bleed counting that abs under by the transmission
Old Nov 25, 2021 | 09:49 AM
tabijan's Avatar
tabijan
Bleed the master cylinder first then ABS if that can be bled then wheels starting with the furthest/longest line from the master cylinder.
You’re moving air from the highest point to the bleed valves. If there’s still air upstream, you have to start as far upstream as the air and keep pushing it to the bleed valves.
Sixto
Old Nov 26, 2021 | 09:06 PM
highest_vision's Avatar
highest_vision
Did you adjust the brake shoes? It is best to do that manually, even though they have automatic adjusters. How does your parking brake pedal feel?
Old Nov 26, 2021 | 09:26 PM
Conanski's Avatar
Conanski
All slack between the rear brake shoes and drum has to be removed via the adjusters or the pedal will never have a factory response.
z56
1997 - 2003 F150
Apr 6, 2018 12:44 PM
Diesel Reaper
Apr 25, 2012 08:47 AM
syver
Feb 8, 2011 04:30 PM
Ken H
Jul 5, 2007 06:26 PM
coxenater18
Bronco II
Jan 25, 2005 07:10 PM
