Sponsored by: Auxito
Ford issues.
Old Feb 26, 2023 | 08:51 PM
Ncfordowner's Avatar
Ncfordowner
3rd Gear
Ford issues.
I had a coolant leak on the crossover pipe on my 5.4 triton in my 2003 f150. Took intake manifold off to fix and discovered it was broke. Bought new intake manifold from Rock Auto. Cross checked everything and it said it would work. Put new parts on and hooked everything back up correctly and it tries to start but only with throttle wide open and it backfires through the throttle body. The air mix box on the bottom of the intake is smaller than the original but not by much. I wouldn’t think this would matter. Some insight would be helpful. Thanks.
Old Feb 27, 2023 | 04:52 AM
manicmechanic007's Avatar
manicmechanic007
The big port on the back of the manifold is open to atmosphere?
Sounds like you have a vacuum leak if it is backfiring through the intake
The hose has a tendency to collapse and tear
Old Feb 27, 2023 | 04:54 AM
Ncfordowner
3rd Gear
Ford issues.
That house that you’re talking about is kinda loose on the new intake. Could it be as simple as a loose hose?
Old Feb 27, 2023 | 07:14 AM
manicmechanic007
it would have to be loose enough to be whistling indicating a vacuum leak
The tee's colapsing and rupturing is what you are looking for and any other vacuum leak, like the power brake booster port
Old Feb 27, 2023 | 08:39 PM
Ncfordowner
3rd Gear
Ford issue.
I appreciate all the comments but it would be a lot easier to check for vacuum leaks if I could actually get it to start and stay running. Which I can’t.
Old Feb 28, 2023 | 03:15 AM
manicmechanic007
After a thorough visual inspection of what you have done
It's time to check the codes
Old Feb 28, 2023 | 02:22 PM
Jon Freeman's Avatar
Jon Freeman
If you suspect a vacuum leak and the engine won't start, do a smoke test.
Old Mar 6, 2023 | 06:46 AM
monckywrench's Avatar
monckywrench
Homemade smoke testers are easy to do cheap and videos abound.
BTroll
Aug 19, 2021 07:36 AM
timbersteel
17
Aug 21, 2013 03:15 PM
WiNgRg
May 27, 2012 12:04 PM
cbzdel
Modular V10 (6.8l)
May 7, 2012 10:01 PM
Cybertaz126
Aug 7, 2004 10:03 PM
