Intake plenums boots
Old Feb 25, 2023 | 11:29 AM
Powerstrokef250's Avatar
Powerstrokef250
4wd Low
Does anyone know if they make plenum boot to adapt a 3inch superduty spider to the 2 inch obs plenums?
Old Feb 25, 2023 | 11:48 AM
z31freakify's Avatar
z31freakify
No, but billet plenums are so cheap it would be wise to just swap them out.
I installed these on my 00 f250
https://www.ebay.com/itm/14479068646...3ABFBM7Kn8mtFh
Old Feb 25, 2023 | 01:54 PM
97-psd's Avatar
97-psd
If you are swapping in the SD turbo, go ahead and change the plenums. They would probably be cheaper than the boots
Old Feb 26, 2023 | 12:36 PM
JCart's Avatar
JCart
As I recall the early 1999 series 7.3 Super Duty had step down plenum boots… although not sure on the exact size. Wanna say the bottom end fit the OBS intake runners and the other end hmmm not sure if they were 3”. Have a look at RiffRaff, they have a ton of nice stuff!
RiffRaff
https://www.riffraffdiesel.com/plenum-cac-boot-kit-early-99/
Old Feb 28, 2023 | 06:11 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yep! E99 boots are your friend.
Old Feb 28, 2023 | 08:31 AM
z31freakify
Totally forgot about the E99 spider boots.
Old Feb 28, 2023 | 08:45 AM
knottyrope's Avatar
knottyrope
wonder if i can make it fit a 95
RiffRaff makes them universal now
Old Feb 28, 2023 | 09:26 AM
z31freakify
You have the eight bolt plenums/heads correct?
not sure they have the same bolt "pattern" as the 10 bolt heads, I don't have 8 bolt heads to check for you,
Old Feb 28, 2023 | 09:50 AM
duck fan's Avatar
duck fan
Because racetruck
Riffraff redesigned their plenums to fit all head bolt patterns and plenums. Now you just choose 2" or 3".
https://www.riffraffdiesel.com/riffr...ums-1994-2003/
Old Feb 28, 2023 | 11:54 AM
knottyrope's Avatar
knottyrope
i think its just extra holes, for 60 bucks its worth a shot if i can get a 3 in y for cheap
Old Feb 28, 2023 | 08:24 PM
97-psd's Avatar
97-psd
I would be interested to know if you find some
Old Mar 2, 2023 | 09:22 AM
knottyrope's Avatar
knottyrope
seems all the 3in is for IC setups
Thought i read about a van spider that is OBS style turbo to 3in
speakerfritz
6.7L Power Stroke Diesel
37
Aug 23, 2023 10:39 PM
aldo_45030
Jul 29, 2015 07:01 AM
