Sagging front end.
Old Feb 21, 2023 | 04:19 PM
56Jimmy's Avatar
56Jimmy
Sagging front end.
My 2000 F350 looks too low in the front. I’ve noticed that mine isn’t the only one though. Looks to me like all of the 2 wheel drives with the 7.3 have the same issue.
I just finished overhauling the front end to see if it would help. Most of the parts had 289,000 miles on them anyway. New wheel bearings, brakes, coil springs, shocks, ball joints, center link and tie rods. Still looks droopy. Lower in the front than in rear.
Has anyone else successfully resolved this problem. Maybe it’s just me and it’s not a real problem. But I don’t like the way it looks. The 4x4’s look fine, like they are sitting level.
I bought some 2” spacers to be installed underneath the coils and some longer bolts to account for the spacers. Also ordered longer shocks and sway bar links. Haven’t installed any of that yet. Wanted to see what others were doing if anything.
I came up with 2” by parking the truck on a reasonably flat surface then measured the top of the front wheel well openings. Then jacked the front till it looked level. It raised the fender openings 2”. Not scientific or remotely accurate but it seems reasonable to me. Thank yu all in advance.
Old Feb 21, 2023 | 08:03 PM
John in OkieLand's Avatar
John in OkieLand
every dually I know of, looks that way.
it is because the rear spring have to be beefy enough to carry the rated load.
it will be level, once the bed has the gross weight in it.
Old Feb 21, 2023 | 08:30 PM
2001F350dualwheel's Avatar
2001F350dualwheel
All trucks really sit lower in the front than the back. It’s designed that way so when you have cargo load in the bed the truck sits level rather than raise the front end. Rear who drives tend to sit lower just because they don’t need the clearance a 4x4 needs so they look even more “saggy”
Old Feb 22, 2023 | 12:52 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
A 2" lift in front is common "levelling" for an unloaded truck.
Old Feb 22, 2023 | 08:11 AM
FordTruckNoob's Avatar
FordTruckNoob
You all know how the rest of this scene plays out.
Old Feb 22, 2023 | 08:51 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
I didn't even need to open this thread seeing that you were the last poster.
I had a pretty good idea of what was coming!
Old Feb 22, 2023 | 09:45 AM
FordTruckNoob
I am glad to have met expectation.
Old Feb 23, 2023 | 05:23 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
2” lift in the front and 2” drop shackle in back will get you level. The 2” drop shackle in the back really only drops you an inch.
Old Feb 23, 2023 | 07:43 AM
JimmyWayne23's Avatar
JimmyWayne23
I’d be interested to know if your truck has lift blocks under the rear springs being a 1 ton. My truck had 2” blocks in the rear that I removed to achieve a “level”. My truck is 4x4 though
Old Feb 23, 2023 | 03:00 PM
bwguardian's Avatar
bwguardian
Probably been 20+ years ago I had a third leaf made for the two sagging there in the front. It picked the front end up to where I have an inch and a half to two inch difference between the front and back instead of the three and a half inches the F350's have. Still looks like the day it got done...
Old Feb 23, 2023 | 03:32 PM
HKusp's Avatar
HKusp
Looks really clean, but the OP's truck is a 2 wheel drive so he has a totally different set-up in the front.
Old Feb 23, 2023 | 03:42 PM
bwguardian's Avatar
bwguardian
Well shoot...guess I missed that...
Old Feb 23, 2023 | 04:02 PM
knottyrope's Avatar
knottyrope
IMO
the big nose on these and a level truck isnt great for looking over the hood on tight windy back roads
im 5-11 and move my face to the wheel at times for a better view
I plan to remove the front helper springs on mine and go with a softer ride
I could pump up the rear bags but its too rough on bumpy roads
95schauf
Jul 16, 2020 09:25 AM
Hog73
Jun 22, 2020 11:20 AM
Fatbob316tx
Offroad & 4x4
Sep 12, 2017 02:21 PM
bokker
1997 - 2003 F150
18
Jul 30, 2008 10:39 AM
