Sponsored by: Real Truck
Clunking sound from front end!!!
Old Apr 12, 2020 | 05:45 PM
Hog73's Avatar
Hog73
Hello all,
Whenever i drive on beat up roads or hit potholes and inconsistencies in the road, i hear a clunking out of my 2000 F350 7.3. 183k miles so what are possible issues and could you ballpark the cost to have it fixed.
i also hear a clunk when i do a full left turn, but nothing to the full right.
Old Apr 13, 2020 | 10:36 AM
Dan Stitzer's Avatar
Dan Stitzer
I have the same issue on my 09 F350. I just got the truck and have already replaced U Joints, ball joints, wheel bearings and sway bar end links. Getting new shocks Tuesday. Next I'll try the springs. Mechanic who did the work on the replacement parts said he couldn't figure it out.
Old Apr 14, 2020 | 01:52 PM
2004 F450's Avatar
2004 F450
You need to find a mechanic that's not just a parts changer until he stumbles on the problem.
Old Apr 14, 2020 | 04:58 PM
seville009's Avatar
seville009
Easy to rule out the shocks - just grab them and wiggle them; they shouldn’t move
had a loose shock thump a few years ago; took about six months to figure it out. Top mount of one of the rear shocks was loose
Old Apr 15, 2020 | 08:39 AM
Juneaudave's Avatar
Juneaudave
Go to the "How-To" Section up top and read through the "Why is my front end clunking?"
https://www.ford-trucks.com/how-tos/...lunking-356131
Old Apr 15, 2020 | 04:00 PM
AACoPD05's Avatar
AACoPD05
For me it was sway bar links. If they are original I'd start there. Easy to do, made a world of difference for me. My symptoms were it sounded like someone was knocking on the bottom of the passenger side floorboard over all bumps.
Old Jun 21, 2020 | 09:44 PM
ITSOT's Avatar
ITSOT
My Ex just developed a clunk up front. Looking for answers, I came across this on Youtube.
Hog, did you ever figure out what the problem was with your Super Duty?
Old Jun 22, 2020 | 12:28 AM
Almostconverted666's Avatar
Almostconverted666
I had a very similar problem. Creaking like clunk over bumps and when braking.
if you have any man meat on your bones push up hard against the side to sway the cab and listen for the sound. If it makes noise doing that there’s a 99% chance it’s your end links or bushings.
youll be able to pinpoint the sound pretty easily as it will come from right behind the wheels in the sway bar area.
if that doesn’t work hop up and down on the bumper and have someone look under it while you do it or vice Vera.
my bushings and links are shot but I just turn on the ac or music because I’ve been a little busy and haven’t replaced mine yet.
Old Jun 22, 2020 | 11:20 AM
bwguardian's Avatar
bwguardian
Originally Posted by Hog73
Hello all,
Is this a 2wd or 4wd truck?
Mander
Jun 18, 2016 07:28 AM
MurderMode
Oct 5, 2013 02:59 PM
aleutianman
Jun 22, 2007 02:19 AM
caitspa
Feb 24, 2004 06:24 PM
