Help please!
Old Feb 22, 2023 | 08:55 PM
FuzzFace2's Avatar
FuzzFace2
I would go steel as the ALUM I think would be a little softer and if using higher spring rates could put a strain on that ALUM gear and strip teeth.
Just my .02
Dave ----
Old Feb 22, 2023 | 09:34 PM
pmuller's Avatar
pmuller
Originally Posted by Bigblock6obs
do I have to buy the kit with two springs or can I use a single sping?
also would a steel or aluminum timing gear be better there is a 5$ difference
You can use a single spring.
The Comp 903-12 spring works.
The Comp 903 fits the stock intake retainers.
You just need to replace the stock exhaust retainers with stock intake retainers and use .050" up locks (keepers) to get the retainers on the exhaust valve near the same height as the intake retainers.
Intake retainers
55-6179 | QualFast High Performance Retainer| Goodson Tools & Supplies
Up locks
Locks, Keepers, Hardened 11/32" X 7 Degree, .050" Up Locks, Raises Retainer Higher, Sold in 1/2 Sets - Alex's Parts Sales (alexsparts.com)
You are using a mild cam with mild valve springs, so the aluminum gear set is OK and I believe it gets quieter than the steel gears as it breaks in.
Old Feb 23, 2023 | 01:51 AM
Bigblock6obs's Avatar
Bigblock6obs
Intake retainers
Up locks
perfect thank you very much you have been very helpful
Old Feb 23, 2023 | 10:24 AM
Bigblock6obs
i forgot to ask but from this point how hard would it be to add a little boost (nothing crazy like 5 lbs) and could i do it safely and not hurting the truck
Old Feb 23, 2023 | 11:23 AM
pmuller's Avatar
pmuller
If you keep the boost at 5 lbs it will be OK providing the ignition timing is retarded with boost and the air/fuel mixture is richened up under boost.
You will have to run larger injectors.
Old Feb 23, 2023 | 12:48 PM
Bigblock6obs
would i also need to upgrade the fuel pump or would that be fine, what size do you think would be best, ive seen some people use 42lb but i think that was for 8lbs of boost
Old Feb 23, 2023 | 03:03 PM
Bigblock6obs
also ive been looking and ik there are alot of people that are not fans of them but what do you think about the comp cams 268 cam?
Old Feb 24, 2023 | 11:42 AM
pmuller's Avatar
pmuller
I don't know what the limits are for the stock fuel pump but if you turbocharge I would suggest that a higher capacity pump be used.
There doesn't appear to be a problem with mild naturally aspirated power upgrades.
You would also need to replace the stock fuel pressure regulator with a boost referenced regulator if you turbocharge.
The Comp 268 cam has low valve lift and will work with your cylinder head since it has short valves and limited valve lift.
The Comp 268 cam kit comes with Comp 903 valve springs and requires that the exhaust retainers be replaced with stock intake retainers along with .050" up locks on the exhaust valves.
The Comp 268 will make good power from just above an idle to 4500 rpm.
Old Feb 24, 2023 | 12:52 PM
Bigblock6obs
sweet thank you, ill get those ordered and installed asap and ill post the results here. If im remebring correct i had private messaged you about the use of the micorsquit, and ill let you know hwat i find out about it.
Old Feb 24, 2023 | 07:52 PM
FuzzFace2's Avatar
FuzzFace2
There are posts on turbo charging and there was something about replacing the head bolts with studs IIRC
Even if not I would to be safe.
Dave ----
Bane270
Mar 10, 2014 02:56 PM
catpwr1
16
Jul 29, 2012 10:40 AM
B-Ryan 02
Aug 5, 2009 09:42 AM
justblowin'smoke
Aug 18, 2005 02:28 PM
