Do I have this diff service correct?
I’ve got a 2015 F250 w/6.7 engine. Looking thru the diesel supplement in regard to differential fluid maintenance, the rear differential does not ever need to be serviced, unless the axle has been under water. If I elect to change the fluid, the recommendation is 75W-140 plus 8oz of friction modifier. Do I have this correct?
If you have the electronic locking differential (the 4wd **** pulls out), you do not need the friction modifier.
Ford Part Name
- Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
Ford Part Number
- XY-75W140-QL
Ford Specification
- WSL-M2C192-A
(1) Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or equivalent meeting Ford Specification EST-M2C118-A for complete refill of limited slip Ford axles. Ford design rear axles contain a synthetic lubricant that does not require changing unless the axle has been submerged in water.
Capacities
Front Axle .................... 5.8 Pints (2.8 Liters)
Rear Axle (1) .................... 6.9 Pints (3.3 Liters)
