Squeel while turning in reverse.
Old Feb 16, 2023 | 01:01 AM
Johndeere guy's Avatar
Johndeere guy
4th Gear
I got a 2019 f250 with 39k miles. I noticed tonight while backing up and turning to the right, I hear a slight squeek or squeel. It doesn't do it everytime. I just had the truck at the dealer for a oil change and had them check over the front end and make sure everything is tight. The truck gets used for snowplowing. Any ideas of what the squeel could be?
Old Feb 16, 2023 | 08:31 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Tire scrub ???
Old Feb 16, 2023 | 09:21 AM
redford's Avatar
redford
FTE Leadership Emeritus
Check your U-Joints.
Old Feb 16, 2023 | 05:53 PM
fordman19762003's Avatar
fordman19762003
Are the hubs locked or unlocked when it makes the noise? If they are locked my first guess is a bad u joint, if they are unlocked then it's something else.
Old Feb 16, 2023 | 06:24 PM
Johndeere guy
4th Gear
Originally Posted by Ltngdrvr
Tire scrub ???
no, running stock tire size.
Old Feb 16, 2023 | 06:27 PM
Johndeere guy
4th Gear
I have them in auto.
Old Feb 16, 2023 | 08:07 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Tire scrub when turning tight, stock size or not.
Tight full lock turn they turn in slightly different radii, makes them squeal.
Old Feb 17, 2023 | 05:29 AM
Johndeere guy
4th Gear
Well last night I plowed snow with the truck for 9 hrs. The whine/squeel isn't very loud, can't here it with the windows up. I noticed that it will make the noise while not moving and turning the wheel at full turn or almost full turn. A buddy of mine says it sounds like the power steering pump or maybe the gear box. The truck just turned 40k miles on it hard to believe the pump or gearbox is giving up already? Does anyone know if Fords power train warranty covers the pump or gearbox?
Old Feb 17, 2023 | 08:45 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Every Ford I've ever had made some pump noise when turning it fully.
My 2015 RAM got noisy and I added some Lucas p/s fluid conditioner and it quieted right down.
Ink4life
Sep 22, 2022 02:11 PM
Garbageman 134
May 25, 2022 10:37 AM
Laconia Excursion
Mar 23, 2017 07:33 PM
FONRDAY
6.7L Power Stroke Diesel
Aug 12, 2012 11:09 PM
ponyrider
Escape & Escape Hybrid
Dec 7, 2008 09:20 AM
