22 F250 reverse pause
Old May 23, 2022 | 03:48 PM
Garbageman 134's Avatar
Garbageman 134
Today I noticed when I put the truck into reverse and let go of the brake there was a two second delay before the truck started moving backwards. I thought because I was very close to something behind me it was some kind of safety feature so I pulled forward and put it into reverse and the same thing, there's a delay between me releasing the brake and the truck moving backwards. Is this normal?
Old May 23, 2022 | 04:42 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Never noticed or paid any attention whether mine does it ever or not, so guess it hasn't that I know of.
So, I would say no, not normal.
Old May 23, 2022 | 06:18 PM
cficare's Avatar
cficare
Was your truck warmed up to normal operating temperature? I ask because I questioned the same thing about backing out of my driveway (cold) and it taking a couple seconds for Drive to engage after I shifted to forward. The pat answer seems to be it's normal until the drivetrain has reached normal operating temperature. Can't say I like the answer.
Old May 23, 2022 | 06:36 PM
2021F350's Avatar
2021F350
Mine does the exact opposite when cold, I put it in D, or R, the truck just jumps and wants to go, like instantly...
Old May 23, 2022 | 07:04 PM
Garbageman 134
The truck was cold
Old May 23, 2022 | 07:15 PM
jstavtx's Avatar
jstavtx
I park my 2021 backed in really close to the garage. It does have the backup sensors, the ones that beep, and on my display I back up until I get in the red zone. sometimes the breaks do hold and if I want to get just a bit closer, have to nudge the gas.
Old May 23, 2022 | 07:18 PM
RidgwaySD's Avatar
RidgwaySD
Mine is pretty harsh and slightly delayed when cold, into R and into D. It dos not do this once even just a little warm, just from a cold start. I do not worry about it. I plow snow with the truck so it does a LOT of back and forth some days and after the first couple of times in the morning it is much smoother. Still does a rare harsh downshift if you catch it just right. I am closing in on 30k miles and it has been the same since new.
Old May 23, 2022 | 07:20 PM
Garbageman 134
The truck was cold
Old May 23, 2022 | 11:38 PM
Tsubakihara's Avatar
Tsubakihara
Mine has done both. Aggressive into drive a couple time. Cold and sitting for a day or two, I drop into reverse and the truck does not move for 5 seconds or so. Every time.
Old May 24, 2022 | 07:32 AM
number9xd's Avatar
number9xd
I always let my vehicles warm up a few min before pulling out. However, I just needed to move my truck out of the way one morning, so turned the key and dropped it in R - and it was hard shift / lurch I’ve read about here. That’s the only time the transmission has ever shifted hard or really lurched.
Old May 24, 2022 | 08:36 AM
RidgwaySD's Avatar
RidgwaySD
I always wait for the rpm to drop to 1000 before selecting a gear. In the winter I let it warm up but until the trans gets a couple miles under its belt I have a slight delay and firm engagements. Never had it sit for 5 seconds as some report, maybe 2 seconds at the longest. Always needed a firm foot on the brake before it has been driven some.
I think the bottom line is, most experience this to one degree or another but transmissions do not seem to be failure prone. Just the challenge of making a very HD unit more car like for all of those not familiar with trucks like this. The six speed in my 2012 had plenty of "character" too. Last truck transmission I actually liked were the manual G56's in Dodge/Ram trucks.
Old May 24, 2022 | 10:12 AM
cficare's Avatar
cficare
My 2022 7.3L 10-spd shifting delay has become quite evident after 4 years with my 2017 6.7L 6-spd which never hesitated when changing between forward and reverse when cold. The hesitation is my only complaint with the 10-spd tranny.
Old May 24, 2022 | 12:18 PM
acdii's Avatar
acdii
My 2018 F150 with the 10 speed (yes I know, NOT the same transmission) does the same thing when cold. It doesn't move right away when put in reverse, a 2 second delay or so before it moves. If I give it gas it will move, but not at idle. It just might be a characteristic with the transmission programming.
Old May 25, 2022 | 10:37 AM
eberlestock's Avatar
eberlestock
I always thought this was just what the lighter duty F250 trannys do! My 2012 had the delay as does my 2017. The heavier 350 tranny doesnt do this.
Frank79
Jun 18, 2021 05:40 PM
FONRDAY
6.7L Power Stroke Diesel
Aug 12, 2012 11:09 PM
grantschim
Nov 23, 2011 01:12 PM
ponyrider
Escape & Escape Hybrid
Dec 7, 2008 09:20 AM
Rockafella
Feb 15, 2003 09:09 PM
