SPEEDOMETER NOT WORKING
Old Feb 14, 2023 | 05:39 PM
U.S. NAVY 7.3 F350's Avatar
U.S. NAVY 7.3 F350
4wd High
Unhappy SPEEDOMETER NOT WORKING
1999 7.3 F350 longbed 4x4. My speedometer and odometer are not working. Overdrive light is blinking as well. Speeding up to 35-75 mph depending on how it’s feeling that day fixes the issue until I slow back down. Already replaced the ABS/speed sensor and didn’t fix it. Whole truck also randomly jerks back and forth randomly until I pull over and turn it off and back on again and then it’s fine, don’t know if that’s associated. Please help! Just a sailor trying to learn how to work on his truck.
Old Feb 14, 2023 | 05:58 PM
Kintla's Avatar
Kintla
Did you replace the vehicle speed sensor in the rear differential?
Old Feb 14, 2023 | 06:10 PM
U.S. NAVY 7.3 F350
4wd High
Yes I did.
Old Feb 14, 2023 | 06:26 PM
Kintla's Avatar
Kintla
Pulling codes would be the first step if the VSS didn't fix it. Everyone here seems to be using ForScan, I've got something else so can't help with that. Regular code readers won't work on our trucks.
With a scanner you could also check to see if the PCM is getting information from the VSS, which would help in figuring out if the VSS wiring is shorting since you know the VSS is good.
Old Feb 14, 2023 | 08:06 PM
kbeefy's Avatar
kbeefy
Motorcraft VSS? Any rear diff work or damage lately? How about wire connector condition?
Theres not much besides the rear diff tone ring and sensor that mess with the speedometer in these trucks. I don't think I've every heard of a cluster stepper motor problem before.
Nathan klouser
Dec 16, 2021 09:12 AM
Cole94
Apr 9, 2021 07:42 AM
scubajt
Jul 9, 2011 10:05 AM
dfarland
Sep 23, 2010 03:06 PM
JICASE
Jan 6, 2005 08:54 PM
