check engine light after cold start
Old Feb 13, 2023 | 07:40 PM
CheezBoy's Avatar
CheezBoy
4wd Low
Hello!
my apologies if this topic exists in the archives--i'm failing to find it via search (i'm a noob here).
i'd appreciate any knowledgeable hints on my issue, please:
2002 F250 7.3L 2WD
immediately after cold starts (below freezing), my engine light is nearly always on.
while light is on, my throttle/pedal is inactive/ineffective.
after several minutes' idle time (typically 2-8 mins), the light goes
out & all is well.
anyone know the offending part/setting?
thanks for your help
Old Feb 13, 2023 | 10:46 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
You'll need to scan for trouble codes with ForScan.
Old Feb 13, 2023 | 10:53 PM
CheezBoy's Avatar
CheezBoy
4wd Low
thanks--will do
Old Feb 14, 2023 | 12:21 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
As a Band-Aid be sure to plug in the block heater a couple hours before start. Warm oil always helps on a cold start.
Old Feb 14, 2023 | 06:33 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@CheezBoy , welcome to the FTE!
Regarding FORScan and the recommended tools to read the DTC, check out the link below.
Link: FORScan + FORScan Lite: Class Tutorial Q&A
If you are wondering where I grabbed the link from in short order, check out the 7.3L PSD Tech Folder which is a sticky thread at the top of this sub-forum. Come back to us with a DTC or two or fifteen and we can help you get the truck right again.
Old Feb 14, 2023 | 08:28 AM
Kwikkordead's Avatar
Kwikkordead
If the throttle is inactive, my first suspicion would be the pedal assembly has lost signal regardless of whether you have a scanner or not. Look inside the plugs for signs of corrosion.
Old Feb 14, 2023 | 10:28 AM
beachcamperf250's Avatar
beachcamperf250
Are you low on oil?
Old Feb 14, 2023 | 12:28 PM
CheezBoy's Avatar
CheezBoy
4wd Low
Thanks to all for your support!--i'll summarize:
- i'm obtaining FORscan as we speak
- the issue exists ONLY during cold/lite on condition, otherwise a-ok. i'll nonetheless look at connector--old truck, so who knows?
- oil level is a-ok
- we live up North, so she's always plugged in wintertime. also replaced glowplugs a couple years back.
starting is ok, just the throttle trouble until she idles several mins.
thanks again--i appreciate your willingness to help
Old Feb 14, 2023 | 04:48 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Lift the accelerator pedal with your toe or hand before starting the engine. If the pedal functions after that, the idle validation switch (IVS) detent is worn.
If it's the non-adjustable pedal 2002 model, a quick way around this is to use a carbide burr on a die grinder and take a very small amount off of the pedal lever assembly where it contacts the pedal stop in the idle position.
The reason you have a dead pedal is because the PCM needs to see a closed IVS switch (idle) to determine that 1. The switch works (for safety) and 2. To set the minimum accelerator pedal position voltage (APP) for that key cycle.
Here's the location of the stop pin and where a smidgen of metal needs to be removed to gain just a touch more travel from the pedal in the full-up position.
Old Feb 14, 2023 | 08:33 PM
CheezBoy's Avatar
CheezBoy
4wd Low
Thanks--i'll try it/have a look
PagosaFord
Jan 23, 2018 11:56 AM
donbrown
May 1, 2010 12:21 AM
sweetsride
Feb 1, 2008 10:46 AM
jhemker15
Jan 19, 2006 12:49 PM
Yeti DHer
Nov 7, 2002 08:39 AM
