Random switch ?
Old Feb 14, 2023 | 02:42 PM
RA67M_'s Avatar
RA67M_
Random switch ?
Hello, I am new to owning a bullnose and found this switch under my dash of my 86 f350 6.9 idi. It was plugged in but I have no idea what it does. Definitely confusing me right now but it’s a 3 way switch so does anyone know what it is for and what it does? Any help will be appreciated!
Thank you for the read
Old Feb 14, 2023 | 03:26 PM
Franklin2's Avatar
Franklin2
Is that your fan speed switch?
Old Feb 14, 2023 | 06:05 PM
RA67M_'s Avatar
RA67M_
You know what ? I think it could be, I’ll test it later tonight
Old Feb 15, 2023 | 07:15 AM
FuzzFace2's Avatar
FuzzFace2
The only other switch that looks close to that but think has more wires is the dual fuel tank switch.
Dave ----
Old Feb 15, 2023 | 07:17 AM
rhythim's Avatar
rhythim
Either fan speed or the fuel tank switch on the right side of the climate control panel.
Old Feb 15, 2023 | 01:04 PM
kr98664's Avatar
kr98664
Originally Posted by RA67M_
Based on the shape of the connector, it looks like the switch for the heater fan motor. See page 152:
https://www.garysgaragemahal.com/com...-testing1.html
Rest of the 1986 wiring diagrams are here:
https://www.garysgaragemahal.com/1986-evtm.html
Old Feb 16, 2023 | 08:55 PM
RA67M_'s Avatar
RA67M_
Well I tested it and with it in the first and second position the fans don’t kick on but with it being on the third/final position it kicks on the fans. I don’t know if it’s the fan speed switch cause my fans seem to only have one speed so switch could be bad then? Not 100% sure on that cause the high-Lo-off switch definitely ain’t doing **** when I move it up and down.
Also thank you to all who replied and gave me your input I really/always appreciate y’all’s time!
Old Feb 16, 2023 | 10:26 PM
FuzzFace2's Avatar
FuzzFace2
I take it all you had was high / fast speed?
If so then the fan resister could be bad, not that un-common.
When under the hood look at the HVAC box where the fan motor is and just below it where I think the fan wires plug in there is athing held to the box I think with 1 screw, that is the blower fan resister, replace it and see if it now has all the speeds.
When there pull the fan motor off the box and clean out all the leaves and junk.
You may even find leaves on the resister NOT GOOD!
That resister gets hot and the leaves then catch fire then burning the rest of the leaves and junk and before you know it the truck is on fire and gone.
So pull the blower motor and clean out the junk.
Dave ----
Old Feb 16, 2023 | 11:09 PM
RA67M_'s Avatar
RA67M_
Dave ----
Ahhhhh I see. I did only have fast/high I believe. I’ll give it a look pretty soon as I’m replacing my heater core anyways. I got the truck with the heater not hooked up cause the core went bad so I’m just now getting around to all the other issues after I got the old 6.9 running.
Also out of curiosity does anyone know where I can find the glow plug/door buzzer? Mine isn’t working or I actually think it’s missing cause I can’t seem to find it anywhere. I read online somewhere that it’s in the glovebox? I checked and I did find a plug in there but nothing connected to it? Will post a pic later but I also know people remove them cause they hate them. Personally I’m a little big/tall at 5’11ish so it makes seeing that weak light hard but I might just put an LED in it if I can’t find another buzzer
Thank you
Old Feb 17, 2023 | 08:36 AM
kr98664's Avatar
kr98664
The buzzer is located above the glove box. You have to remove the liner to see it:
https://www.garysgaragemahal.com/upl...09430_orig.jpg
How many wires on the plug? Was it under the glove box? If only one or two wires, those may be for the courtesy lights. The lights were optional, but I think all harnesses had the provisions.
If this plug had 7 wires, that was probably for the buzzer.
Old Feb 17, 2023 | 06:47 PM
RA67M_'s Avatar
RA67M_
like this ????
if so, how can I replace it ? I heard OBS chimes work on the bullnoses but what year should I be looking for like 92-96 or 97+ still works ?
Old Feb 17, 2023 | 06:58 PM
Franklin2's Avatar
Franklin2
Good luck finding any year that still works. What do you want it mainly for? If you want a headlight reminder, they are easy to make yourself.
Old Feb 17, 2023 | 08:31 PM
FuzzFace2's Avatar
FuzzFace2
How true
In the 3+ years my truck has been back on the road I have only heard it buzz once and I dont have a clue what I did to make it sound.
It would be nice to have it work if I left the head lights on as I have done that 1 or 2 times.
Dave ----
Old Feb 22, 2023 | 09:40 PM
RA67M_'s Avatar
RA67M_
How true
Dave ----
Funny cause today I finally went to the junk and pulled two modules. They both worked, even got different years and I’m happy they both ended up being different modules. I got a buzzer and chime, I stuck with the less annoying chime though.
Also for those wondering
I had the typical ****ty ford problem, needed it cause my door was hard to close and wouldn’t close some times so it would pop open. I fixed it though so now I’m using the chime to let my dad and others who drive my truck know when the engines ready to start instead of that dim light in the bottom.
Thank you all for your input !!!!
4B11TX
Sep 27, 2021 09:49 AM
Squirrel13
Jul 19, 2021 01:59 PM
Jeff64F100CrewCab
Aug 4, 2019 01:47 PM
redman84
Ford Truck Parts for Sale
Jan 21, 2012 11:33 AM
strokin'_tatsch
Feb 12, 2011 11:48 AM
