Odd vibration noise
Old Feb 13, 2023 | 10:03 PM
my3sonsdad's Avatar
my3sonsdad
Odd vibration noise
Do you know the sound a long steel cable makes when you hit it - that twanging vibration noise and somewhat high pitched?
That’s the sound my 2001 7.3 Ex started making at or near highway speeds after hitting a bump, pothole or uneven pavement seams across the highway. Initially it was a short duration but most recently it has extended. the tone/pitch does not change with speed. It also occurs more frequently when turning or cornering to the right suggesting that it’s coming from the driver front wheel or suspension when it under forces, which is where I hear it. However a front passenger indicates they hear it coming from the rear passenger side. What’s odd is that it went away entirely for several weeks and then returned.
this all started after I had driven some rather rough backcountry roads in 4x4 Low and engaged/disengaged the wheel locks.
anyone encounter this before or have any suggestions on what to start investigating or ruling out?
Old Feb 13, 2023 | 10:58 PM
lctravis's Avatar
lctravis
1st Gear
I had a similar experience when the inner roller bearing cage failed on a cheap off-brand driver side unit wheel bearing/hub.
I would hear the exact noise you described and while it was not consistent, it did occur more often if I hit a pothole or made a quick steering adjustment.
I had purchased a truck that needed front end maintenance. Ordered steering components and unit bearings. When I pulled the driver side for replacement, about 2/3rd’s if the needle bearings fell out and the cage was absolutely mangled. New bearings on and the sound never returned during my ownership of the truck.
I would suggest inspecting unit bearing.
matthew.monroedc
Jul 27, 2021 04:49 PM
Gary Lewis
2015 - 2020 F150
Dec 14, 2016 01:19 PM
mytruckisjunk
Dec 9, 2009 11:37 PM
av226
Mar 31, 2007 09:08 PM
