I saw on a thread a while back someone made wiring connections by using a male and female stock type connector and pulling the needed wires out of the loom in between them. I would vastly prefer that to the old Scotch-Lok method to get signal from my fog harness and high beam harness, which I want to trigger relays for my aftermarket driving lights. Can anyone tell me where to source the different factory type connectors? I've done some searching both here and online and not found what I'm looking for. Thanks!
) really good quality considering the price. 4 pin and has rubber seals for a factory water resistant connection. I used them for relay for driving lights myself. I also used them to route front speaker outputs to rear of cab and some other projects. Note: the leads are 16 awg.
I might be misinterpreting your question, but if you are looking for the pins that fit the Molex connector for the fog lights check out my info in this thread: https://www.ford-trucks.com/forums/1...l#post19172822
The 12 pin connector for the cargo lights is the same style (but different pin count?) as the fog light plug under the front bumper on driver frame rail. I used my leftover pins from the cargo light project to add pins/wires to the fog light plug to add my fog lights.
