Communication Error multiple networks
Old Feb 12, 2023 | 02:03 PM
Trubennis's Avatar
Trubennis
2nd Gear
Ideas neeeded!
I apologize, I thought the vehicle info showed up…
2012 F-250 6.7 Diesel
Vehicle had a bad alternator, batteries went dead. To get the truck to a garage, the batteries were swapped for new ones and then the alternator was swapped for a new one.
When driving to the garage, before the new alternator, almost all dash lights illuminated, Speedo dropped to zero, warning on display read an AdvanceTrack error and check brake system ABS warning.
Since the new alternator these error messages pop up intermittently, do not kill the truck but cycle through start-up mid-driving.
Ideas needed to help identify the possible location of the issues!
Old Feb 12, 2023 | 04:22 PM
Just Chilling's Avatar
Just Chilling
Are we working on a Tesla, a Prius or a kenworth.
make model year, cc and ss number would help.
Old Feb 12, 2023 | 04:49 PM
Trubennis's Avatar
Trubennis
2nd Gear
Sorry, I thought it was shown… I’ve edited, thank you.
Old Feb 12, 2023 | 07:58 PM
Just Chilling
3 places on those trucks that are a common problem. Plug by parking brake pedal comes loose. Plug at rear of truck beside the spare tire gets water in it.
And fuse box under hood get water in it. This one is not quite as prevalent as the other two.
All three make the truck do really weird things. Good luck.
Old Feb 12, 2023 | 11:48 PM
HRTKD's Avatar
HRTKD
If it wasn't something that the bad alternator caused, I would look for wires that are missing insulation and have grounded out.
Old Feb 13, 2023 | 05:22 AM
Overkill2's Avatar
Overkill2
Thinking about this, I remember on my 96 F250, that the rebuilt alternator I got was bad right out of the box. Just as an idea, maybe have the alternator output checked to see if it's good to eliminate that as a possibility.
Old Feb 13, 2023 | 08:25 AM
DIY'er Learner!!'s Avatar
DIY'er Learner!!
6th Gear
Dash & Radio Going Schizo
Originally Posted by Trubennis
Ideas neeeded!
I had this same issue and just about went insane trying to locate and remedy it!! I followed all the advice on here and checked the harness at the e-brake and in the rear of the truck, to no avail.
One day, while pulling my radio out to get some information off it, I decided to look behind the digital dash to see if there was anything out of place. There is a harness that ties the digital dash into the back of the radio. I disconnected the harness and cleaned it off with air, then reconnected it. Seemed like a tight fit, so I put it all back together and carried on.
After about 3 days, the problem began again..... GrrrrI went back in and while in there, I realized that during the day it would be rather warm (65+ degree's) then at night it would cool off (mid 30's - mid 40's). I disconnected the harness, used some electrical spray cleaner, then put a light coat of dielectric grease on the female side of the harness, reconnected it, then took two small zip ties (one mid-left and one mid-right) and tightened them down to prevent any movement between the male & female side of the harness ( be careful not to damage any wires).
This was done over 3 weeks ago, and it has not disconnected or cause my radio and dash to go schizo on me since.
Give this a shot and hopefully it will resolve your issue as well!
I have a 2013 F-250 6.7l, Black Ops Edition, by Tuscany, SRW, Quad Cab, 4x4
GOOD LUCK,
Hope this helps you out
2013 Super Duty 6.7 l SRW Black Ops Edition by Tuscany 6" BDS Body Lift w/ Fox 2.0 Shocks 20" Black Ops Rims 37" Nitto's Self installed Cab Clearance Marker Lights Purple T-20 led's in bottom of headlights (Self-Installed)
Liz77
6.7L Power Stroke Diesel
Sep 13, 2023 05:42 AM
U-Haul Owner
Large Truck
Nov 12, 2021 07:56 AM
adammdennis11
Apr 21, 2015 07:40 PM
DeBoerJM
Apr 14, 2014 08:06 PM
El Gato
Jul 30, 2006 01:08 AM
