Replace Tire or Not
Old Feb 12, 2023 | 07:16 PM
aklim's Avatar
aklim
Originally Posted by Beast 17
You do you and I will do me. That’s my opinion. Don’t skimp on tires.
I agree. My concern is what happens if it blows out and I get hurt. Like I said, truck is an item. It can be replaced. My body parts, not so much. As such, my body is my concern so I will not skimp on tires.
Old Feb 12, 2023 | 08:29 PM
1olddogtwo's Avatar
1olddogtwo
Originally Posted by elee3
If you have 20” wheels, your spare will be an 18”.
DRW...........
Old Feb 12, 2023 | 08:55 PM
Bruce M.'s Avatar
Bruce M.
Originally Posted by 1olddogtwo
DRW...........
Exactly.
Put the slide rules away and make it a spare... Be done with it.
Old Feb 13, 2023 | 02:46 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I'd run it. Just keep it on the rear.
Old Feb 13, 2023 | 10:18 AM
CheeseheadFord's Avatar
CheeseheadFord
Originally Posted by leadmic
The white you see for the raised white letters so I say it would be completely safe to run the tire. The outside rubber is to cover the white.
Are you looking at the same pic the rest of us are? Why do you think this is the case?
Old Feb 13, 2023 | 10:51 AM
DPelletier's Avatar
DPelletier
You may as well swap it for the spare, but I'd have no issues running that tire on the back of a DRW truck
Dave
Old Feb 13, 2023 | 11:33 AM
AZDUALLY's Avatar
AZDUALLY
Originally Posted by Just Chilling
Why would warranty cover damage? That’s not a faulty tire.
Because all they can say is No? Just rolling the dice...
Old Feb 13, 2023 | 11:37 AM
redford's Avatar
redford
FTE Leadership Emeritus
If that were mine I would replace it, even if the warranty didn't cover the damage.
Old Feb 13, 2023 | 11:48 AM
AZDUALLY's Avatar
AZDUALLY
Dave
I am going to have it swapped to the spare. I probably would be ok with on the DRW as well,
Old Feb 13, 2023 | 01:11 PM
AZDUALLY's Avatar
AZDUALLY
@leadmic is actually correct - I went to Discount tire today to see what they had to say. The tire has black rubber over the cords on the sidewall then white (for the white lettering) then another layer of black rubber. So the opinion of Discount tire was that they are fine provided they are not losing air.
I typically run 14 ply on my trailers and I have seen them be just fine with similar scuffing. I have not used these Michelin tires before - but they seem much better then the Nexens that my Rams come with.
So I am old enough to know that I do not always know everything - learn something new everyday.
Old Feb 13, 2023 | 03:51 PM
CheeseheadFord
Interesting.... the tire has to be weaker at that point though, right? If I'm using my truck for hauling or towing, which I'm assuming you are since you have a DRW I'd replace it if nothing else for my peace of mind. Last thing I'd want would be a blow out while towing due to failure of a tire that could have been prevented. Obviously its your rig so do as needed, I don't know much about tires, but common sense tells me there is some structural damage there, whether its worth worry about or not I don't know,
What's the difference in this and dry rotted tires? Are dry rotted tires rotted all the way through maybe?
Old Feb 13, 2023 | 04:52 PM
OverheadCram's Avatar
OverheadCram
I have one trip on my truck and about 1800 miles. I noticed one of the rear tires has a some damage to the sidewall.
Is this significant enough to replace the tire?
Do you by chance know what damaged it? was it road debris or light contact, or did something impact it with force? Being you can only see what's superficial, if the damage was indeed incurred from an impact I would personally throw it away. You wont be able to tell if you distorted the sidewall plies beneath the rubber body casing. If you did distort any of the plies and they start to shift or tear you may be lucky enough to catch it in the form of a ripple in the sidewall or bubble but only after heating it up during a drive cycle that it may blow out on before you even know.
Old Feb 13, 2023 | 06:22 PM
  #28
Squanto's Avatar
Squanto
Some black silicone sealant would fix it.
Old Feb 13, 2023 | 07:17 PM
  #29
AZDUALLY's Avatar
AZDUALLY
The cords (10 ply)are what provide the structure and strength I believe - the damage is only superficial not sure how much strength the rubber side wall provides outside the 10 ply.
Old Feb 13, 2023 | 07:30 PM
  #30
AZDUALLY's Avatar
AZDUALLY
I bought the truck on a Saturday on 01/03 then that Sunday drove it to Colorado unloaded. I cant say when or where the damage occurred - I do not remember any anything that sticks out that would have caused that damage. It being my 3rd dually I don't curb check my tires - but dual's' tend to ride up the curb anyway and not rub the sidewalls.
Personally I think something backed up in to the tire during transport or it rubbed on the transport truck - but I didn't notice it when I took delivery so I am probably going to have to replace it myself. I am going to run it until I put a trailer on it - then I will have to decide how its looking I guess.
