Hi! I recently modded my air intake, and now my truck is idling rough, and doesn't seem to even have as much power as it had before.
I have a 1993 4 cylinder, 2.3L Ford Ranger. I replaced the stock air intake with a kit that included a K&N cone filter and a new metal tube. Everything fit together ok, -except- for a hose that came out of the exhaust system (for emissions control?). There was no place to put it into the new system. It ran so badly I finally extended the tube and put it as flush as possble against the filter (it entered the intake before the filter in the original setup). This runs fairly well, but I still notice the above problems.
Where exactally does this hose come from + went to?
Is your vehicle carburated or injected?
Your symptoms suggest a deactivated EGR + carb venturi icing!
And...you are talking about 2 different things here, aren't you; a hose + a tube?
I want to get all the facts straight!
and for the original: http://web.umr.edu/~afreese/threea.jpg
1) is where fresh air was sucked into the air intake.
2) where the exhaust hose(above) hooks into the air intake.
3) where the filtered air connected to the block.
There actually couldn't be a "port" for that hose in the new system, as the pictures show, the hose attached in front of the filter, and since there isn't anything in front of a cone filter, there isn't a good place for it to attach.
"carb venturi icing" = is only for carburated motors, yours has a throttle body.
"deactivated EGR" = yours may not be working to it's fullist because of the changed air filter, thus changing your intake vacuum + overall performance.
I suggest replacing the old unit (I know that is going to be a real pain in the butt!) and then check out your performance.
*I was wondering if the problem that you are having, would happen in a 2.3L because I was contemplating doing the same as you w/ my 2.3L.*
**These "little engines", along w/ this "new technology", makes it harder for us to be able to make any process improvements.
It takes so little to throw them off kilter!**
***I've heard that this K&N system does work on the larger engines after reading past posts on this subject!***
A freind of mine had told me that he left the snorkle (as he called it) off his wifes Ranger when he reinstalled the engine and it actually ran better/performed better. I have removed the one from my Ranger (94 2.3L, 5 speed) completely, installed a K&N air filter in the stock location and found that maybe it helped a little (anything extra from that gutless engine is welcome), it certainly didn't run worse. That hose provides heated air, which is controlled by a vacuum operated valve on the snorkle, by running it direct to your new air filter you are ingesting heated air all the time. Now by doing this, you have in affect richened the mixture because heated air is much less dense than cold air and have defeated any purpose for the Cold air induction add on.
It sounds to me like you have an induction leak, leaning out the mixture and or completely messing up the Mass air flow sensors input by allowing air to bypass it though a leak. You might try running the engine at idle and gently spray contact cleaner around the hose couplings, if there is a leak the engine will faulter, run rough and maybe stall out when the cleaner gets drawn into the engine through the leak, if so then you have found your leak.
Good luck
Look in your Haynes manual for how to pull the codes. BTW, not having heated air from the exhaust manifold "should'nt" be any big deal except for cold starts on cold days.
Where should I look for info on pulling codes?
I've been looking at the EGR stuff, and it does sound like a problem in it, possibly a dirty mass air flow sensor;
Under the "EGR Control System" heading in my Haynes manual, the very first words are "If a code is displayed" and I don't see any info there on getting codes. I've looked through the book, so if the info's there, it's hidden pretty well.
