Plenum gasket install
Old Feb 10, 2023 | 01:29 PM
bdwiggin's Avatar
bdwiggin
94 Ford F150 351W 5.8L V8
I replaced my fuel injectors this morning and am ready to re-install the Plenum. Do I need to coat the gasket with anything prior to the install? Any recommendations with the installation process to ensure a proper seal? All torque specs will be followed. Thanks for any input.
Old Feb 10, 2023 | 01:53 PM
Prototypemech's Avatar
Prototypemech
It's perfectly acceptable to install the intake gasket dry. There's no water passages in the plenum so there no risk of water leaks. Installing it dry will allow you to remove it later when needed, with out any cleanup work.
Old Feb 10, 2023 | 02:37 PM
jas88's Avatar
jas88
I always use Permatex Hi-Tack spray. It's not for better sealing per se, it's main function is to help hold the gasket in place. Been using it on gaskets since the 70s.
It's especially effective on cork gaskets (to keep them from sliding out under pressure) which, granted, you don't see too often anymore.
Old Feb 10, 2023 | 03:13 PM
Scndsin's Avatar
Scndsin
I made some 5/16ths studs, 2 is enough. Opposite corners.
100% gasket doesn't move & holds the upper still to start the rest.
Take'm out or use'm.
turbocoupe88
Oct 12, 2020 06:01 PM
emkay4597
Feb 4, 2011 08:26 PM
Duke78
Sep 22, 2007 12:04 PM
PAUL_2
May 22, 2002 04:50 AM
