So I've changed the fuses for the power points, along with the cigar lighter (seem to be 3 different fuses?). I can only seem to get the lower power point working.
The top one was working until a few days ago when something was plugged in, it turned off and hasn't come back on.
Checking continuity, it seems to have nothing between power and ground (checking the back part against the side metal).
Is there something that commonly happens that I'm missing? Or am I gonna have to pull it out?
Ceramic may have cracked in the lighter socket, will have to pull the dash and look, I have a mystery ground, plug anything into the lighter and pow, fuse blows, 3 lighter sockets later same, so I replaced the lighter socket with a power port, no more issues, I don't smoke its just for powering things, no lighter.
