Persistent 400 Front Seal Leak
Old Feb 10, 2023 | 07:24 AM
She'llRun's Avatar
She'llRun
Okay I found ONE on ebay! Thank you for spurring me to look again. When I install the slinger, should the concave side of the slinger be facing toward the block or toward the timing cover?
Old Feb 10, 2023 | 09:27 AM
ranger140892's Avatar
ranger140892
Grumpy goat
Oh I was afraid you were gonna ask that. I don't remember. The last one I did was on a 460, and that slinger is flat.
Someone here will know. But if not, it's easy to figure out which way it installs. I remember using a straight edge across the timing cover mounting surfaces on the block. I slid the slinger on the crankshaft, laid the straight edge down (accounting for gasket thickness), measured from the straight edge to the slinger, then I went to the timing cover and measured how far the seal stood out from the mounting surface. Then I turned the slinger around, and repeated the process. I seem to remember that the concave faced forward, but I'm not 100% on that.
Old Feb 11, 2023 | 08:04 AM
headloct's Avatar
headloct
The oil slinger was originally used to provide lube to the plastic timing gears.These gears were an attempt to quiet engine noise.Roller setups require way less lube and oil mist and splash is all that's needed.Ask any big engine builder.Slinger won't hurt anything as long as it fits and doesn't contact the chain or gears but not needed with roller.
Old Feb 11, 2023 | 08:15 AM
ranger140892
Grumpy goat
Yep, all of the above
But if you're running a mechanical fuel pump, don't forget the fuel pump eccentric. It still needs all the oil it can get. Especially a one piece eccentric.
ScottyC50
Oct 3, 2021 05:20 AM
Jay Is Jay
Feb 22, 2017 01:14 PM
Phil Fleming
Jun 28, 2016 01:42 PM
redone1
Jun 12, 2010 05:52 PM
dfwf250
Mar 12, 2007 09:51 PM
