Time for new engine?
Old Feb 5, 2023 | 09:07 PM
Hydrodebo's Avatar
Hydrodebo
1st Gear
Hey, long time lurker, first time posting.
2006 f150 4x4 5.4 just hit 250,000 miles. About a month ago after a short trip to town and back, had that horrible diesel sounding rattle. Waited half hour and restarted, went away. Oil was good and clean. And didn't happen again during daily drives. 2 weeks later, drive over 50 miles and it starts rattling, dying at stops and threw a engine light. Have to get codes pulled tomorrow, but from what I've read from here it either exhaust leak, timing, phasers or oil pump.
I love this truck and don't want car payments. I can afford a new engine if needed.
So what's yalls advise? Is it worth putting in a new 5.4 when that engine has all the problems from thier original design, or is there a better crossover?
Old Feb 7, 2023 | 11:49 PM
tbear853's Avatar
tbear853
" Worth" of doing a swap vs changing a truck depends on plans. If you want to keep it and aren't interested in resale, I'd fix it. It's my plan for my '07 if ever needed.
250,000 miles and still running doesn't read like junk to me.
You can get codes pulled for free at most auto parts places, but a code reader ain't expensive.
Old Feb 8, 2023 | 12:02 PM
redfishtd's Avatar
redfishtd
Sounds like you should zero in on the problem first . You may be able to get another 100k out of it . The codes are important to us not some vague idea of the problem .
History of truck would be good too . Mean while drop your oil pan and look for parts and inspect , clean out oil pickup it may be clogged . Open up those valve covers check out those rollers /cams . There is a lot to look at .
Rollers are a frequent fail on these engines ,you may catch it before bad damage . You can also see the health of the phasors at that time . You can do a lot from the top .
You can do an crank end play check also , usually excess end play will require a reman .
Remans are a lot of work it is not without trouble , a lot of stuff moves over. The fluids/ gaskets etc are not cheap , You will despise the mounting bolts for the power steering . Exhaust studs can be a real challenge .
I'm not saying throw a lot of money on the engine rebuild , just learn and try to get it to go until it can't . There will be a lot of help on here .
P0rkins
2004 - 2008 F150
Jan 22, 2023 05:24 PM
cmejia1231
2004 - 2008 F150
35
Sep 30, 2022 07:44 AM
FordHubby
Modular V8 (4.6L, 5.4L)
Jul 5, 2017 08:29 PM
gopitt98
2004 - 2008 F150
Aug 11, 2011 06:03 AM
Darcampo
2009 - 2014 F150
16
Jul 2, 2011 05:38 AM
