Engine Knocking on a 5.4
Old Aug 10, 2011 | 09:19 AM
gopitt98's Avatar
gopitt98
Hello All,
I have a 2006 F-150 with a 5.4 that has 75,000 miles on it and I have owned it for the last 3 years and bought it with 14,000 miles. I have never had a problem with my truck until I started to hear a knock. It started to occur when driving on vaction through the mountains of West Virginia, and North Carolina. I noticed first when using the cruise while going up the mountains before it would kick down to a lower gear to get up the side. It has never done that before, even towing my boat under a load. I kept my ear open and it seems like it is getting a little louder and know can hear it even when there is no load when the crusie is on at a low RPM. I changed the oil before I left, put 2300 miles on in two weeks and then changed the oil when I got home and the knock is still there. I have always had my local Ford shop service my truck. Is the knocking going to lead to a big problem. Looking for some advice as what to do.
Jim
Old Aug 11, 2011 | 06:03 AM
slc10844's Avatar
slc10844
Any chance it could be an exhaust leak? Check the exhaust manifolds for broken or missing studs. If you suspect a internal engine problem, you can take an oil sample and send it out for analysis. An analysis will give you a break down of what is in the oil and that should tell you if the engine is starting to fail.
Argess
Jan 16, 2011 09:15 PM
1Bonzai
2004 - 2008 F150
Dec 22, 2007 05:50 PM
JjimrB
1997 - 2003 F150
Jan 9, 2003 01:32 AM
tinman_r75
Feb 12, 2001 01:09 PM
