ZF6 S6-750 to 300 I6
I don’t care how hard it will be or what it will take. I’m looking to adapt a ZF6 (stronger S6-750 version) to my 300 I6 in my 1980 F250. I know this truck is like three generations away from the ZF6 trucks but I’m sure it’s do-able. Just wondering if anyone has put one of these in a F250 Bullnose I’m certain it’s been done. This wasn’t exactly in the how-to so I’m making this post. Any and all help is greatly appreciated, thanks in advance!
I dont think anyone has posted if it has been done
Just off the top of my head what you will have to deal with.
You will need to swap over to hydrolic clutch, not hard as the later bull nose used them.
The later 5sp and guessing the 6sp is no speedo cable hook up as they run off the rear end.
Now the big one is the transmission bell housing to motor bolt pattern.
The 300 six is a small block pattern what is the 6sp that you are going to use as I dont know the newer stuff?
If it is also a small block pattern then it is down hill from there I think.
If not then you will need to find an adapter to work.
Keep us posted
Dave ----
Keep us posted
Dave ----
The following users liked this post:
on
I know it’s brutal lol but there’s gotta be a way. Machine a plate that has the 7.3 power stroke AND 4.9 Straight six holes is my guess
The following 2 users liked this post by FuzzFace2:
can’t just get a longer shaft? Will probably have to be custom made anyway due to different diameter and spline count
I know you don't need any naysayers in this thread, but have you studied what you will gain? Both ends of the ratios on a 6 speed are close to the 5 speed zf, all you are gaining for all this is a extra gear in the middle. But keep on keeping on.
And it seems you already know Ford broke their previous pattern and only the later transfer case will bolt to the 6 speed. That would be the easiest way around that.
TheDudeAbides
07-29-2022 01:26 PM
