How to install digital dash clock first time?
Old Feb 16, 2023 | 06:33 AM
flashgordon_F250's Avatar
flashgordon_F250
7th Gear
Hello,
I would like to replace the stock black-plastic-placeholder in the dashboard of my 1984 F-250
by the time-correct digital clock
Unfortunately it looks that the current black-plastic-placeholder field is somehow fix/connected with the entire dashboard …
(I know the radio is not stock and needs to be replaced aswell)
Any advise for that swap?
Old Feb 16, 2023 | 08:01 AM
FuzzFace2's Avatar
FuzzFace2
First know there are 3 different clock plugs for the 80 - 86 trucks so 3 different harness for them.
IIRC the clock is part of the main harness but many years since I messed with the clock.
The wiring is not that big a deal once you know the wire colors and what they do.
Now for that panel there are 2 ways to go about this.
Find a panel that is for a clock with the openings open - good luck on that as most are cut for a different radio or wrong wood grain.
Cut yours open for a clock.
I was lucky that my parts truck had one or I got 1 off Ebay that was for a clock but was cut for a different radio but was usable.
The one that came with my truck was all black and had been painted many times by a PO and broken.
Removing the paint did not go well and it was broken pretty good too.
The clock I got off Ebay think had a different plug but came with the pig tail so was able to splice it into work once I found what the wire colors did.
Dave ----
Old Feb 16, 2023 | 09:07 AM
Olds64's Avatar
Olds64
It doesn't look like your dash has been cut to accommodate that radio. Good luck installing the clock.
Old Feb 16, 2023 | 12:26 PM
flashgordon_F250
7th Gear
You mean, a stock radio will not fit ?
Old Feb 16, 2023 | 01:53 PM
Olds64's Avatar
Olds64
I just mentioned that it looks like the radio in your pic was installed without hacking up the dash. That's a plus in my book.
I removed the radio/clock panel in my Bullnose truck once. I don't recall that it was super difficult. Just look for screws down low and start by removing the ash tray.
94yj
Jun 30, 2022 05:04 PM
hobbie1
Feb 17, 2022 02:05 AM
Tugly
55
Sep 3, 2021 01:37 PM
unleashd
Oct 17, 2017 09:32 PM
rcn
Jan 11, 2010 10:07 AM
