7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Nearing 100k maintenance
Old 03-23-2023, 04:30 PM
d7velo1's Avatar
d7velo1
d7velo1 is offline
Sparkplugs look good for 94.400 miles!
Thanks for posting the pictures... I'll be sure to not pull in my spark plug replacement too much after seeing how good yours look.
I agree, the huge amount of room in the engine compartment with the 7.3L makes me smile as I do all my own maintenance as well.
  #32
Old 03-23-2023, 05:36 PM
scraprat's Avatar
scraprat
scraprat is online now
Received 2,515 Likes on 1,317 Posts
I'll also note that the truck didn't run rough or lose on mileage either.
  #33
Old 03-30-2023, 01:37 PM
MBuckholz's Avatar
MBuckholz
MBuckholz is offline
Maybe it is obvious, but hopefully you did a brake fluid complete change?
  #34
Old 03-30-2023, 02:15 PM
scraprat's Avatar
scraprat
In all my years, no never have. Never felt brake fade or notice discoloration of the fluid.
I should though because it's not that hard to turkey baster it out a couple times for fresh fluid change. 😉
The following users liked this post:
  #35
Old 03-30-2023, 02:27 PM
GAZZILLA's Avatar
GAZZILLA
GAZZILLA is offline
Received 1,091 Likes on 596 Posts
Doesn’t brake fluid and antifreeze become corrosive over time? I try to change all fluids every five years.
  #36
Old 03-30-2023, 03:08 PM
rvpuller's Avatar
rvpuller
rvpuller is online now
Brake fluid is corrosive from day one, get some on your trucks paint and leave it there for a day.
Denny
  #37
Old 04-06-2023, 06:34 AM
4wheelsandahitch's Avatar
4wheelsandahitch
4wheelsandahitch is offline
Could you tell a difference between the old shocks and the new ones?
  #38
Old 04-06-2023, 08:40 AM
scraprat's Avatar
scraprat
No I never could tell the differences in shocks even when I had more expensive ones on. The truck is always carrying wieght which helps with ride by itself. The Monroe shocks have always served my purpose.
  #39
Old 05-17-2023, 03:59 PM
scraprat's Avatar
scraprat
Crawled under the truck and did another oil change, figured I'll just keep putting the maintenance or repairs and future UOAs in this thread. I'll do the Blackstone UOA in the 25k range. I'll be keeping this truck for 200 - 250k miles again which should be another 2-3 years.
Last couple oil changes I haven't been able to get MC820s filters, been using Fram Tough Guard TG2 in its place.
92,146 odometer (7,776 miles) 21%, engine hours 2,258, idle hours 668
100,970 odometer (8,824 miles) 12%, engine hours 2,555, idle hours 795
Maybe give present or future owners something to look forward to for longevity or shorten life some think with extended oil changes. 😉
The following 4 users liked this post by scraprat:
  #40
Old 07-21-2023, 05:23 PM
scraprat's Avatar
scraprat
Crawled under the truck for another oil change.
109,000 odometer (8,030 miles) 20%, engine hours 2,798, idle hours 893.
Before changing the oil started truck for a few minutes then turned it off and let sit for a few minutes and this is what the level looked like. No oil was added in the 8,030 miles.
The following 2 users liked this post by scraprat:
  #41
Old 07-24-2023, 06:53 AM
FishOnOne's Avatar
FishOnOne
FishOnOne is offline
Received 1,462 Likes on 904 Posts
Oil looks pretty clean for 8k miles
  #42
Old 07-25-2023, 10:35 PM
jcb206's Avatar
jcb206
jcb206 is online now
Originally Posted by scraprat
Denny I'm in the same boat for rotors never turned one and other than one replaced that warped on my 88 so changed the fronts.
@kry226 Mileage is why. Brake pads are cheap at $75 for front and rear at 92k miles, that is a steal for preventative maintenance. If you're going to regrease the slide pins which should be part of maintenance why not change the shoes at those miles, especially if doing it yourself.
So how often should I replace the brake pads?
  #43
Old 07-26-2023, 07:48 AM
rvpuller's Avatar
rvpuller
What I do is replace at 50 to 60% wear and check the slide pins every 30 to 40K miles. From my experience pulling heavy loads when the pads get past 50% it affects excessive heat transfer to the calipers. I've never had to replace a caliper, rotor or turn a rotor on a truck I bought new and maintained myself
Denny
  #44
Old 07-26-2023, 10:51 AM
kry226's Avatar
kry226
kry226 is offline
Denny
Protecting the caliper is a good point too.
  #45
Old 08-04-2023, 03:06 AM
carl2591's Avatar
carl2591
carl2591 is offline
yeah wondering the same thing.. if the pad on left is old and on right is new in picture above shocks you screwed yourself out of some 30K miles of usage. thats like 50% left or so.. I know they are not expensive but that is wasting money.. did you flush out the brake fluid in each wheel as well with new?? that is as important as new pads..
Originally Posted by kry226
Any specific reason you did the brake job? Were you experiencing fading, noise, or another issue? If the rotors were good, and the pads still have lots of life left, not sure I'm following your reasoning.
Quick Reply: Nearing 100k maintenance
