Block Heater Working?
Old Feb 4, 2023 | 08:19 AM
GotAll4's Avatar
GotAll4
How do you know if the block heater is working? Have to use the truck today and 10* this morning here in Ohio. I normally don't drive it in the winter so last night I plugged it in and in about an hour I went out with my infrared thermometer shot the block and where the big wire goes into the top of the oil filter housing. Both read the ambient air temperature at 15*. Is that a true test or not? Also it took about 4 times to start this morning. Ran rough then smoothed out after a minute.
Old Feb 4, 2023 | 08:47 AM
pvdiag's Avatar
pvdiag
Easiest way to check if it is functioning is to watch your electric consumption meter on the house. If the heater is working, even if only at "half power", you will see an immediate jump in the spinning meter as soon as you plug it in. Or on the counter of you have a digital one. You might need a helper for this quick test.
Old Feb 4, 2023 | 08:51 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
There is an ohm/resistance test you can perform on the element prongs. You should be able to hear the element making a bit of noise right after plugging it in, almost like a bubbling. The area around the element base should be warm to the touch, at least warmer than ambient temperature. If you lift the hood after the heater has been running a while, you may notice the trapped warm air rush by.
It appears your element is not working properly. You can either test the element and replace as needed, test the cord and replace as needed or replace everything.
Are you sure the breaker didn't trip? The heaters draw a lot of amperage based on the extension cord specifications.
Old Feb 4, 2023 | 08:56 AM
RA101725's Avatar
RA101725
Banned
I'd plug in a lamp to the socket first and make sure it's not dead. An hour is not going to do much though. 3 or 4 will.
Old Feb 4, 2023 | 09:41 AM
Kwikkordead's Avatar
Kwikkordead
I've only plugged mine in once years ago to see if it works. I could hear the element sizzling in the block. Obviously you won't be able to hear that if you're parked next to a busy street, but I lived in suburbia Seattle at the time, and I could pick out the sound easy enough. Same sound you get on an electric hot water heater when it's heating back up.
Old Feb 4, 2023 | 10:02 AM
Old and soft's Avatar
Old and soft
Read my oil temp on my moniter during the glow plug cycle. At 10 *f my oil temp is about 60*.
Old Feb 4, 2023 | 10:27 AM
Walleye Hunter's Avatar
Walleye Hunter
I use two methods. 1) When I plug it into the extension cord, it arcs and 2) as stated above, you can hear the sizzle in there pretty soon after plugging it in. You should also notice a little warmth in the extension cord after prolonged use.
Old Feb 5, 2023 | 12:55 PM
GotAll4's Avatar
GotAll4
I did check the breaker and it's on the same circuit that my Triumph cars are plugged into and all 3 lights were on the battery tenders I have them hooked up to. I did hear some noises but not sizzling sounds. That's the first time I needed that to work. Like I said for now I don't use my truck in the winter but in another year that will change so I will need it to work. Anyone know the resistance reading for the element?
Old Feb 5, 2023 | 01:26 PM
kbeefy's Avatar
kbeefy
I think it's under 10 ohms. If it's bad it will be very high resistance or open.
I try to plug in for at least 4 hours if I know I will need to start it between 32 and 20 degrees, overnight if below 20 degrees.
The cord will be warm to the touch after being plugged in a few hours.
Old Feb 5, 2023 | 04:38 PM
FinnishStroker's Avatar
FinnishStroker
Sizzling sound is a good way to check it.
Power consumption may vary but If no sizzling,no heating.
Old Feb 5, 2023 | 04:39 PM
Kwikkordead
When I lived in Seattle, there were many mornings that the temperature would drop to well below freezing and I NEVER had any difficulty in getting it started. I can see using the heater if it's below zero myself, but why bother with it if it starts up on it's own reliably?
Old Feb 5, 2023 | 04:43 PM
kbeefy's Avatar
kbeefy
Dropping below freezing in Seattle is alot different than 20 in Anchorage AK. Why punish it.
FinnishStroker
Common guideline says here in Finland,use block heater when weather is below 5celsius.
Personally i start using it around -5celsius.
Old Feb 5, 2023 | 06:50 PM
pvdiag's Avatar
pvdiag
For my old dearly beloved e99, and for my current 2002, I feel compelled to "plug it in" at less than -10F/-23C. But it also depends on what the weather has been for the 2 or 3 days prior.
But 3 or 4x per winter, I find myself in an airport parking lot when it has been sitting at -10F or colder out in the open for a week+ (and always late at night). No plug in option. I have org'd myself with knife-switches and a huge NoCo booster to get me through this design case. So far so good.
Earlier today, I started my truck after 3 days of -20F/-28C and night time wind-chills 20F/10C colder. Outside temp at the time was +12F. There is no way the block of that truck was anywhere near +12 after that stretch. 2 GP cycles and the on-board charger plugged in, and it started up around 10 seconds of crank time.
Old Feb 6, 2023 | 08:00 AM
GotAll4's Avatar
GotAll4
Thanks all! Saturday was one of those days that there were appointments one right after another and we need the payload of the truck for the 1st. So I needed it to start so Murphy's law didn't kick in. 10* is rare here and the truck hadn't run in 2 months and as you know the longer it sits the harder it is to start. That was the first time trying to start it at that low of a temperature. When I get a chance when the weather warms up I'll check the ohms. Crazy weather here it's suppose to get to 50 tomorrow and be much milder for the next week.
@FinnishStroker My grandparents immigrated from Finland. Kiitos!
