dana 24 transfer case
Old Jan 31, 2023 | 10:46 PM
69 f250 4x4's Avatar
69 f250 4x4
1st Gear
I have a 69 ford f250 4x4 with dana 24 tranfers case the rear wheels wont turn or roll i was tld the dana 24 sometimes binds up?
Old Feb 1, 2023 | 01:47 AM
1TonBasecamp's Avatar
1TonBasecamp
Never personally heard of them having a problem like this even semi-regularly. Can't remember if I've heard of it happening at all, but it does not sound impossible.
Have you verified that the front and rear differential gearing is the same?
I would say you need to verify where the binding is happening. Can you shift the transfer case? Can you remove the driveshaft(s) to make sure it's not a problem with the rear end itself?
Good luck. Sounds like more than one potential culprit still at this point.
paul
Old Feb 2, 2023 | 07:04 AM
fe390pc's Avatar
fe390pc
Paul has very good ideas there. First verify that the rear end is not the issue.
theCretin
Dec 3, 2021 10:08 PM
flyingtexan
Dec 15, 2006 05:40 PM
rrawlins
Jul 16, 2003 10:12 PM
Goodold71
Nov 7, 2002 06:57 PM
