SPE CCV and external catch can, Anyone done this?
I’ll be doing this exact install and trying to use a Racor ccv6000
The Mishimoto oil catch can system is designed to fit right under the factory CCV box, with fittings that fit into the ports on the valve cover, which retains a stock appearance while rendering the CCV box useless because the one fitting plugs the out port I believe, and the other fitting intercepts and sends the CCV gases/oil mix to the catch can. It's essentially a plug and play kit. No modifications. The Mishi cans have a drain port on the bottom as well.
The following users liked this post:
It's weird how it turns oil looking stuff into a light tan color by said oil/other contaminants absorbing the water caught in winter as the engine burns off the condensation that forms when the hot oil cools off in the cold temps. Yeah, I like keeping that schitt out of the intake as well.
https://www.parker.com/content/dam/P...entilation.pdf
I don't understand what you mean with being stock or deleted. How would this matter with a ccv reroute mod?
Okay just looked up the CCV box and came up with this box... but this is saying it's for the non-sensor version.
https://swagperformanceparts.com/16-...15030a81bdcfa4
You can see what I mean on the plastic hose coming off that CCV box... it would be difficult to seal it to a fitting because it's made from plastic.
If you want a CCV reroute/bypass, get rid of the CCV box and go with one these kits or similar...
https://swagperformanceparts.com/swa...e-reroute-kit/
Here's the link to SPE's kit because this is what this thread is about.
https://www.spemotorsport.com/products/ccv-reroute-kit
I still want the fumes to get back into the intake, just minus the oil and water. I don't want the stink of CCG coming out of the truck. My original thought, the SPE CCV that traps oil and returns it to the pan and the catch can to get everything else that gets by and returning clean gasses to the intake.
I haven't looked at any catch cans yet, I keep seeing morimoto but haven't seen any links to it. I figure since I will be in that area installing the S&S return filter, might as well tackle both.
this is the same can from mishi's powerstroke kit - https://www.mishimoto.com/ford-6-7-p...-kit-2017.html
I'm going with morimoto due to the size of the racor unit.
#28
#29
I was looking at those yesterday, but the CCV box stays in place and it mounts where the S&S filter mounts. I may wait a bit as I may want to remove the top of engine filter and put the SPE filter kit in after I see some reviews. Then there is plenty of room to mount this can.
#30
