SPE CCV and external catch can, Anyone done this?
#61
#62
what's the FS2000?
I had FS2500 engine oil bypass filters on all of my other diesels. I haven't got around to this one yet.
I don't think you were referring to this gun
https://www.guncritic.com/product/fn...erica-fs-2000/
The following users liked this post:
#63
We've heard from plenty of owners who have slowed or stopped oil leaks with a reroute. I've even heard some say their truck feels noticeably more powerful, or maybe more responsive with a reroute. I would be interested to see how many 6.7l owners on this site (or anywhere), who have rerouted their CCV, have also ran into turbo seal leaks. That would certainly help back that gentleman's claim.
The following 4 users liked this post by 4wd6.7L:
#64
That wasn't a 6.7 in the video, and he is saying leave it stock showing a truck that has other mods done to it. I like that guys channel, but this is apples and oranges. A plugged 6.7 CCV is will cause more issues than that truck has. That "reroute kit" looks like it was sourced at home depot, and is reduced by close to half the diameter with a 90 deg. fitting designed for pressurized water, have a look at pressurized water fittings compared to DWV fittings that are for gravity flow systems for a visual comparison. Also on the 6.7 the CCV system is closed off under boost and even more CC pressure builds stressing the seals in ways that can't happen on a properly designed OCV system like the one from SPE.
ETA: I am not saying anyone should change to an open system, just that the video is not a valid reason not to change.
#65
There's no doubt the FS2500's do an awesome job.
I also ran some Amsoil bypass filters, but always preferred the FS2500.
I thought maybe there was also a FS2000 that I never knew about.
I also run the return to the oil fill tube, .not the cap. It's not often I remove the fill cap with the engine running.
I noticed decades ago, it's better if you point the nipple for the return slightly down and it eliminates the splash.
#66
I tried the spin on and went back to the canister.
I also ran some Amsoil bypass filters, but always referred the FS2500.
I also run the return to the oil fill. It's not often I remove the fill cap with the engine running.
#67
I found this kit from SPE Motorsports that may be of interest to those wanting to keep a closed crankcase ventilation system but be able to check and clean the system. It is a little spendy, but is a well thought out and good looking set up. From the looks of it a person could add the "cheese grater" catch can available for the reroute kits if they wanted.
#68
I've been rocking the spin on conversion since it first came out... I actually cut open one of the used spin on filters and they are impressive. I am now running a set of obsolete Filter Mags, an older set meant for a industrial application because of the large diameter of the spin on filter, on the FS2500 spin on filter that I got for the price of a Filter Mag hat. I was inquiring about the industrial filters, made for oil filters on factory generators and hydraulic systems, but they cost some coin. The guy from Filter Mag offered the set I have now for free if I bought a hat from the website. I'm going to cut open the filter when I replace it and will post up here...
Please tag me or whatever to keep me informed.
I've been using the marine cartridges because they're slightly lower micron.
When I was running and guñning,. We had several vehicles to maintain - we put ovér 2 million - mostly trouble free miles on our old GMT400 6.5 diesels.
I attribute that to the bypass filters, Fluidamprs, servicing the timing chain every 200,000 miles or so and servicing injectors every 125,000 miles or so.
The time saved by running 20,000 mile oil changes was huge.
We did oil samples, sporadically.
I have trouble keeping up with 30,000 miles a year of maintenance now. Back then I put 45,000 miles on one vehicle in 9 months. That 1989 C2500 lasted 800,000 miles.
I just kept doing the same things to every vehicle as we acquired them.
Bypass filter, Fluidamprs, Amsoil, B11 fuel. - before Ulsd, the fuel was much more bio friendly.
#69
I also believe it's a good place for a filter before the oil is reintroduced.
I have always liked to keep the vacuum on the crankcase on all of my vehicles
The following 2 users liked this post by jrsavoie:
#70
#71
#72
#73
They will tell you how long you can run your oil.
#74
Yes and they will tell you that you can't go that long. And with the money spent on oil tests and bypass filters and additional oil, you could have just changed the oil. I'm not knocking you, I used to think the same as you but after talking to some mechanics and seeing it first hand, fuel dilution is a real issue.
#75
