Engine timing direction?
Old Jan 31, 2023 | 12:11 PM
Keithfowl's Avatar
Keithfowl
4wd Low
Hand cranking the timing on the engine, not the distributor…. does it matter which direction it rotates? I’ve been told different things.
it’s a 1986 f150 5.0l, EFI
Old Feb 1, 2023 | 01:37 AM
1949f1's Avatar
1949f1
I have done it both ways over about 40 years and never had any trouble but the best way I find is to pull the plugs out and put a socket on the crank and use a ratchet and turn it clock wise from looking at the front of the engine.
Old Feb 1, 2023 | 05:51 AM
Franklin2's Avatar
Franklin2
Turn the engine the normal way it runs, which I think is clockwise on the pulley. That will take any slop out of the timing chain and will also make the advertised firing order be correct.
Old Feb 1, 2023 | 09:51 AM
White Lightnin''s Avatar
White Lightnin'
I always turn the crank clockwise
jesterdog
Jul 21, 2008 10:49 AM
Jrock909
Jul 25, 2006 02:02 PM
Gregstopspeed59
Mar 8, 2005 05:42 PM
GSchretter
Oct 6, 2004 02:06 PM
Dannym
Aug 13, 2004 02:29 PM
