Oil cooler
Old Jan 31, 2023 | 10:11 AM
CGriff71's Avatar
CGriff71
4wd Low
Oil cooler
Has anyone ever used the updated oil cooler from carparts?
Old Jan 31, 2023 | 02:06 PM
FiveOJester's Avatar
FiveOJester
I wouldn't trust anything when it comes to the oil cooler. Either OEM or Bullet-proof diesel. All of the "upgraded" oil coolers typically end up being inferior in every way. Larger passages to prevent cloggging = less surface area for heat transfer and higher oil temps. High oil temps in a 6.0 is very bad!
Old Feb 3, 2023 | 09:14 PM
CGriff71's Avatar
CGriff71
4wd Low
So on the "updated cooler" front you're talking about, wouldn't the updated part also apply to the supposedly new updated oem coolers I've seen advertised along with all other coolers that are not factory oem? Even including BPD.
Old Feb 13, 2023 | 06:26 PM
FiveOJester
Yes the OEM has an updated oil cooler with an extra row of cooling.
On aftermarket units I wouldn't trust anyone unless they actually show performance data or a cut thru the cooler to actually back up their claims.
Not sure what BPD uses in their kits, if you're interested call them and ask.
But at the $300 price point for the OEM cooler why even bother with aftermarket?
Old Feb 13, 2023 | 06:43 PM
bismic's Avatar
bismic
.... and just because it may be advertised as an OEM updated oil cooler, it doesn't mean it really is.
Franks250
Mar 25, 2022 06:26 PM
Oh no 6.0
Apr 21, 2017 11:33 AM
wisevoss
Jan 29, 2014 04:51 PM
High Binder
Oct 21, 2010 08:19 PM
036liter
Apr 15, 2010 08:01 AM
