WHOOPS! diesel fuel into my 85 f150
nooooooooooooooo...don't do that.....just had a guy do that in a van where i work....drain it out of your tank as much as you can....pull the line off at the filter and let the pump run fresh gas out of the tank through the lines....replace the filter also...need to also drain the lines up to the injectors by suction or something...might have also harmed the pumps if ran to much on it......
tonyfranciozi
05-06-2007 08:12 PM
fastbigblockford
10-20-2005 08:42 PM
jetski310
11-16-2003 04:18 AM
