WHOOPS! diesel fuel into my 85 f150
Old 11-14-2003, 05:30 PM
jackfast1's Avatar
jackfast1
jackfast1 is offline
Angry WHOOPS! diesel fuel into my 85 f150
85 f150 302 efi... 5 gallons of diesel added to gasoline tank!
running ROUGH!!! what should i do??????
Old 11-14-2003, 05:53 PM
D Harry's Avatar
D Harry
D Harry is offline
I don't know. Fill it with premium and see if you can run it out I guess.
Old 11-14-2003, 08:12 PM
74F250's Avatar
74F250
74F250 is offline
nooooooooooooooo...don't do that.....just had a guy do that in a van where i work....drain it out of your tank as much as you can....pull the line off at the filter and let the pump run fresh gas out of the tank through the lines....replace the filter also...need to also drain the lines up to the injectors by suction or something...might have also harmed the pumps if ran to much on it......
Old 11-16-2003, 06:02 AM
sadisticglee's Avatar
sadisticglee
sadisticglee is offline
i thought 86 was the first year for efi on 302 ?
Old 12-18-2003, 12:25 PM
BigCrzyRdNeck's Avatar
BigCrzyRdNeck
BigCrzyRdNeck is offline
it should not hurt anything never heard of it hurting just fill up and check your plugs when done. Its like putting marvel oil in your gas which you should do every now and then to help keep things movining freely I've seen poeple do it in 90 model cars it just smokes some.
jazz1
12-27-2011 09:43 PM
tonyfranciozi
05-06-2007 08:12 PM
fastbigblockford
10-20-2005 08:42 PM
jetski310
11-16-2003 04:18 AM
Dave85zxt
01-15-2003 05:57 AM
Quick Reply: WHOOPS! diesel fuel into my 85 f150
