2022 Wheelwell liners
Old Jan 29, 2023 | 06:51 AM
  #31
Gharri30's Avatar
Gharri30
Originally Posted by HeavyAssault
Okay...on my 2022 Lariat I have "fabric" of sorts front liners. They seem to be a covering over the stiffening material in between layers. They are easily OEM as I've had them on previous year trucks. Are the front ones (part numbers above) a hard plastic style like the rears will be with the other part number??
You are correct. Just a few minute job to do.
Old Jan 29, 2023 | 09:12 PM
  #32
number9xd's Avatar
number9xd
Originally Posted by shawnee1
Penda makes the wheel liners for Ford. You can buy the rear liner from Penda at Advance Auto Parts, Part # 7010270X. As far as I know, the fronts are only available from Ford. I have the Penda rear liners on my 2019 F250. They fit perfectly. The instructions in the box had the Ford logo on them.
They are listed at $134.99 on-line (www.advanceautoparts.com). There is a 20% promo code for on-line orders - 673Z1 which drops the price to $107.99.
Same here. Can also find them on Amazon.
BTW - if you get the front plastic liners, go ahead and get the front bumper inner liners too and complete the deal.
Old Jan 29, 2023 | 09:16 PM
  #33
rklavoon's Avatar
rklavoon
[QUOTE=
BTW - if you get the front plastic liners, go ahead and get the front bumper inner liners too and complete the deal.[/QUOTE]
THIS! Worth the $50 to keep the road salt out of the front bumper.
Old Jan 30, 2023 | 09:03 AM
  #34
ToMang07's Avatar
ToMang07
Did the front wheel well liners and bumper guards at the same time. Well worth the investment and it's an easy install.
Old Jan 30, 2023 | 12:55 PM
  #35
HeavyAssault's Avatar
HeavyAssault
What brand did you use Penda or OEM??
Old Jan 30, 2023 | 01:02 PM
  #36
4wd6.7L's Avatar
4wd6.7L
The only option for the front liner is the Ford labeled part (made by Penda). For whatever reason the rear liners can be purchased under the Penda name, but not the fronts.
Old Jan 30, 2023 | 01:03 PM
  #37
HeavyAssault
What about the smaller bumper area liners as pictured above??
Old Jan 30, 2023 | 01:06 PM
  #38
4wd6.7L's Avatar
4wd6.7L
Same, Ford part only, although I have no idea who manufactures them.
Old Jan 30, 2023 | 01:19 PM
  #39
Gharri30's Avatar
Gharri30
I have the part numbers for those liners as well if someone needs them.
Old Jan 30, 2023 | 01:20 PM
  #40
HeavyAssault
Please share! Thank you!
Old Jan 30, 2023 | 02:17 PM
  #41
Gharri30's Avatar
Gharri30
Left Fender Liner Extension -- HC3Z16E207A
Right Fender Liner Extension -- HC3Z16E206A
I want to say that they only come with two pins to install them but require four and I had some extras laying around the house. I would have to look back into that though to confirm that.
Old Jan 30, 2023 | 04:04 PM
  #42
number9xd's Avatar
number9xd
See also
https://www.ford-trucks.com/forums/1...l#post20383036
Old Jan 30, 2023 | 05:31 PM
  #43
ToMang07's Avatar
ToMang07
OEM from the Stealership
Old Jan 30, 2023 | 05:36 PM
  #44
ToMang07's Avatar
ToMang07
Need the hardware kits too.
Old Jan 30, 2023 | 06:20 PM
  #45
Gharri30's Avatar
Gharri30
I thought so. I just went and found my stuff. I bought the clips and screws but never used them. I have a box of retainer clips and I just used 4 of them, 2 per liner plus the 2 they provided, instead of the screws/clips.
