2022 Wheelwell liners
Old Jan 28, 2023 | 02:31 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by Jmcx1969
He said the kid in the back who installs them had to cut and mangle these particular ones to get them in. When he saw he had them taken back off.
Seems like a jump for him to then make a claim that the 2022's are different. The kid in the back might not be too bright either haha.
Old Jan 28, 2023 | 02:36 PM
shawnee1's Avatar
shawnee1
Penda makes the wheel liners for Ford. You can buy the rear liner from Penda at Advance Auto Parts, Part # 7010270X. As far as I know, the fronts are only available from Ford. I have the Penda rear liners on my 2019 F250. They fit perfectly. The instructions in the box had the Ford logo on them.
They are listed at $134.99 on-line (www.advanceautoparts.com). There is a 20% promo code for on-line orders - 673Z1 which drops the price to $107.99.
Old Jan 28, 2023 | 06:08 PM
MrTnT's Avatar
MrTnT
I used two cans of spray rhino lining that you can get at any automotive store for the rear. Looks much much better cost about 20 bucks. Wish the fronts were as easy.
Old Jan 28, 2023 | 07:34 PM
Rwhjr's Avatar
Rwhjr
over time that won’t stay very nice due to the grit/bumpy texture. It’s hard to keep clean. I like my factory liners because they clean so easily when I’m washing the truck and look brand new every time.
Old Jan 28, 2023 | 07:35 PM
Southsounder's Avatar
Southsounder
I put ford liners in the front wheel wells on my 2022 F350 today, no fitment issues. When ordering online I had to enter that my truck was a 2021 to get past the "these don't fit your vehicle" warning.
Old Jan 28, 2023 | 07:52 PM
MrTnT's Avatar
MrTnT
They clean easy enough, but no they won't clean as easily as plastic. If you prep the surface correctly it last a long time. Can always add another coat as well. I have done this on all my trucks and never had an issue.
Old Jan 28, 2023 | 08:05 PM
Rwhjr's Avatar
Rwhjr
isn’t there also a gap where you can see more frame and the underbelly of the truck bed without the liner?
I have an XL without liners at work.
I don’t ever have the 21 XL in my possession since it’s used by others, but I feel like it has a very unfinished look/gaps if I remember correctly.
the liners are cheap enough, and do a nice job being low maintenance while providing a nice finished look that i’d just buy a set of my truck didn’t have them.
Old Jan 28, 2023 | 08:10 PM
rklavoon's Avatar
rklavoon
I moved my front and rear wheel liners from my 2020 F350 to my 2022 F350 with no issues. Fitment was the same.
Old Jan 28, 2023 | 09:34 PM
MrTnT's Avatar
MrTnT
Not really, just proposing a simple solution to fords oversight.
Old Jan 28, 2023 | 09:36 PM
Gharri30's Avatar
Gharri30
As stated above, part #HC3Z16F099A works just fine for the front on 2022s. I ordered mine from Fairway Ford Parts back in June for around $145.
Old Jan 28, 2023 | 09:46 PM
HeavyAssault's Avatar
HeavyAssault
Okay...on my 2022 Lariat I have "fabric" of sorts front liners. They seem to be a covering over the stiffening material in between layers. They are easily OEM as I've had them on previous year trucks. Are the front ones (part numbers above) a hard plastic style like the rears will be with the other part number??
Old Jan 28, 2023 | 09:48 PM
rklavoon's Avatar
rklavoon
The ones that come standard in the front are the felt ones. The additional ones you can add from Ford are hard plastic.
Old Jan 29, 2023 | 04:53 AM
  #28
connman12's Avatar
connman12
Have the wheel liners on my 22 Platinum.. front and rear..with no issues...glad I order them...the work real well..thy keep a lot of dirt and dust out..and are easy to clean..
Old Jan 29, 2023 | 06:03 AM
  #29
Squanto's Avatar
Squanto
Delete dup
Old Jan 29, 2023 | 06:06 AM
  #30
Squanto's Avatar
Squanto
Lots of parts inventories haven't been updated to include 22. I just received a set of OEM horns that are not listed as even fitting an F-350 at all. But lists 17-21 Expedition.
