Electrical Problem
Old Feb 3, 2023 | 05:43 AM
fordf348's Avatar
fordf348
Check out this video it sure helped me
Old Feb 3, 2023 | 10:54 AM
hooler1's Avatar
hooler1
Originally Posted by fordf348
https://www.youtube.com/watch?v=MBHtXMTNUXA
That's a great video!
Here's another handy tool I found on the 'net. Every time a friend asks me about their charging system not working when using or replacing a generator I have to pull it out and look at it because I can never remember the appropriate procedure. If done wrong you could ruin a perfectly good voltage regulator. I have been there and done it so I always look at the diagram first. You want to actually disconnect the wires and short them together as shown. That will isolate your voltage regulator in the event of a damage or shorted Field in the generator.
For our Fords, use the one on the right hand side. Type B:
Ford most Fords, use Type B
Old Feb 3, 2023 | 01:55 PM
fordf348's Avatar
fordf348
That video was sent to me By Tom Maine or Maine Tom
Old Feb 3, 2023 | 02:09 PM
abe's Avatar
abe
Tom's username is pineconeford.
Old Feb 4, 2023 | 09:55 AM
leonharu's Avatar
leonharu
I have good service with this.
https://www.napaonline.com/en/p/ECHV...pressionRank=1
Old Feb 4, 2023 | 10:34 AM
hooler1's Avatar
hooler1
Originally Posted by leonharu
Yes sir! That must be a good unit as I have seen quite a few of those under 6 volt hoods at car shows.
Old Feb 6, 2023 | 01:44 PM
ReForder's Avatar
ReForder
A new voltage regulator is needed but not sure what is considered "quality" anymore. I got mine from Carpenter, but I'm sure it's chinese but it works for now.
As noted, that battery has long since passed it's date of death. Also as noted, THICK battery cables will help flow as much juice out of those 6V batteries even as they get a bit weaker over time (not dead, as in this case).
cbutcher
Feb 4, 2023 09:52 AM
PavMav
Apr 20, 2010 06:30 AM
qman
Electrical Systems/Wiring
Jul 18, 2009 08:15 AM
qman
16
Jul 16, 2009 09:19 PM
Pablo-UA
Aerostar
Apr 11, 2007 12:08 AM
