Brake Shoe Adjustment
Old Jan 25, 2023 | 05:41 PM
old28's Avatar
old28
On a 1971 F250 Do you turn the star adjuster up or down to expand the brake shoes.
On the front , can you turn the star adjuster all the way to lock & back it off 5-8 notches?
Can you adjust the rear brake shoes the same way? Do not know if rears have self adjusters.
Old Jan 26, 2023 | 12:08 PM
1TonBasecamp's Avatar
1TonBasecamp
Don't know for sure, but by '71 I would think that all would be adjustable and self-adjusting.
Following along to see what others with knowledge say about it.
Personally, I would just try adjusting them and see what you get. As far as I know you can't hurt it unless the adjuster will go all the way out and the two halves part company.
Other than that, it's hard to go wrong by experimenting. The truth should come out pretty quickly.
Paul
Old Jan 26, 2023 | 02:37 PM
catastrophejustin's Avatar
catastrophejustin
if i remember right, one goes up and one goes down. i believe the driver side went up
Old Jan 26, 2023 | 03:27 PM
kenny nunez's Avatar
kenny nunez
Self adjusting brakes
To tighten the shoes the end of the tool goes down on all 4 wheels. I usually tighten until I cannot move the wheel then back off 10 clicks. Sometimes after test driving they need to be re adjusted if the pedal is too low.
Before self adjusting brakes the adjustment was the opposite. Tool pries up to tighten and down to loosen.
Working at my Dad’s shop the first time I did a brake job on a 62 Ford with self adjusting brakes it took me about a 1/2 hour to reassemble the first wheel before I finally figured it out.
Old Jan 26, 2023 | 06:37 PM
old28's Avatar
old28
Thanks guys for the information. I will go with what Kenny Nunez posted.
I had read that if you have self adjusters that if you tighten them to much they can not turn back as they have locking notches. Is this a bunch of CR**? Can my 1971 star adjusters be turned both ways to get the adjustment correct. What about this Kenny? and others.
Old Jan 26, 2023 | 07:13 PM
kenny nunez
Brake adjustment
The star wheel will back off. Just be sure to have a good adjusting tool.
Old Jan 26, 2023 | 09:00 PM
catastrophejustin
Kenny's right. My bad. I went and looked at my truck and it seems that both adjusting screws are for the rear left when there side specific. My self adjuster on the driver side wasn't working.
Old Jan 26, 2023 | 09:02 PM
catastrophejustin
I guess I wouldn't have noticed since I have only driven it about 100 miles
Old Jan 27, 2023 | 01:09 AM
1TonBasecamp
If, for some reason, the notches are so precise that it doesn’t want to turn in the loosening direction, you can take a second tool, such as a small screwdriver, and push the star ratchet plate slightly away and out of engagement with the star wheel.
At that point, you can turn the wheel without resistance in either direction.
Old Jan 27, 2023 | 12:16 PM
old28's Avatar
old28
Thanks again guys, been many years since I adjusted brake shoes on a 70's truck.
Old Jan 31, 2023 | 11:21 PM
JEFFFAFA's Avatar
JEFFFAFA
I guess I "dare to be different". On adjusting drum brakes, I adjust out until I can only spin the tire, with both hands, one revolution. Both sides being equal. This way I only have to adjust out.
A 6 of one / 1/2 dozen of another type of thing.
KoreanFord
15
Oct 31, 2021 09:41 PM
Pastor Scott
Feb 3, 2017 09:01 PM
OneTon4Fun
Jan 25, 2011 05:02 PM
Nightintruder
Nov 29, 2010 07:27 PM
61 uni
May 23, 2009 06:01 AM
