AC compressor doesn’t turn on
Old Jan 29, 2023 | 06:11 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Anonymous12
How would I properly do that? And how would I tell if it’s the switch or the Freon? And why didn’t I have battery voltage there? Is it referring to the switch on the climate controls or something else?
Check the air gap with a feeler gauge. You would need pressure gauges hooked up both the high and low service ports. Why didn’t you have voltage to the compressor? Because the low pressure switch prevents the clutch from engaging if there is a problem.
Old Jan 29, 2023 | 10:17 AM
mlanoux's Avatar
mlanoux
And when I jumped it the clutch engaged.
what exactly did you jump?
Old Jan 29, 2023 | 12:13 PM
My4Fordtrucks
Put a jumper wire across the low pressure switch (harness) terminals.
Old Jan 29, 2023 | 12:35 PM
mlanoux's Avatar
mlanoux
I'm just trying to verify that's what the OP did.
Old Jan 30, 2023 | 02:44 PM
Anonymous12's Avatar
Anonymous12
I jumped the plug that goes on the drier by the vacuum reservoir. The clutch engaged. I’ll have to go buy a feeler gauge I don’t think I have one.
Old Jan 30, 2023 | 08:48 PM
mlanoux's Avatar
mlanoux
So that tells me either the switch is bad (unlikely) or you're low/out of refrigerant...you have to put gauges on it to tell if it's the latter.
Old Jan 30, 2023 | 09:52 PM
rocketroy's Avatar
rocketroy
When you mentioned the accumulator is that the large round black cylinder thing with two pipes coming out of it ?
thanks
Old Jan 31, 2023 | 04:03 AM
My4Fordtrucks
R-12 systems only have a low pressure switch so that is the only one he could have jumped
thanks
Yes. Accumulator; receiver/drier
Old Jan 31, 2023 | 11:39 AM
rocketroy's Avatar
rocketroy
Ok thankyou ..
Old Jan 31, 2023 | 01:03 PM
mlanoux's Avatar
mlanoux
The OP stated: "With the blower motor on low and the ac switch turned on the climate control panel it has power 10-11v. And when I jumped it the clutch engaged." ...from this context the "it" could have been the ac switch in the control panel, that's why I asked for clarification.
Old Mar 22, 2023 | 12:55 AM
Anonymous12
I’ve been thinking about it. I noticed the plug on top of the ac compressor the clip is broken. It made me thing is there any sort of wiring that’s screwed up I can check that will cause it to not turn on?
Is there a loaner gauge for r12 ac systems so I can check the pressure?
Old Mar 22, 2023 | 11:45 AM
Anonymous12
Originally Posted by kenny nunez
Just for kicks check the clearance of the clutch halves air gap.
Im gonna do that to. I need to finish up my problem with the water pump bolt. Then im gonna move onto AC most likely. As 100+ degree weather is on its way in a few months.Do they still loan gauges for R12 ac systems?
Old Mar 22, 2023 | 12:02 PM
  #28
mlanoux's Avatar
mlanoux
my local O'reilly does
Old Mar 22, 2023 | 12:17 PM
  #29
Anonymous12
Ok, ill loan some of those. And do I connect it to the low side which I think is the blue cap on the Ac dryer. And the high side the black cap next to radiator and radiator reservoir? Or is the high and low side something else?
Old Mar 22, 2023 | 12:22 PM
  #30
DBGrif91's Avatar
DBGrif91
You stated in post #20 that you jumped the terminals at the low pressure switch and the clutch engaged. The clutch wouldn’t engage if there was a problem with the wiring, so I’d recommend focusing on the charge level of the system.
Also, are you certain it still uses R-12? I know it’s not impossible but it seems unlikely that a 35 year old truck hasn’t had any AC service.
Do not rely on the under hood label for the type of refrigerant it’s using - the system could’ve been converted and a new label was never applied.
If you’re unsure, post a picture of the high and low side service valves - it’s easy to tell if the conversion has been done by the valves.
