1995 E40D
Old Jan 24, 2023 | 10:39 AM
shkawgo47's Avatar
shkawgo47
3rd Gear
1995 E40D
I have a 1995 F250 (2wd) with the 5.8L / E40D drive train that suddenly developed a rough shifting issue. By sudden I mean all was well, but when I took off from the next stop light, upshifts and downshifts rattled my teeth. I figured a good place to start (simple solution first) was to drop the pan, clean & inspect, and fill with fresh fluid. I don't know if/when the fluid was ever changed (114,000 miles). Then a buddy mentioned there is a vacuum line to the tranny that may have cracked / come loose / etc. Any suggestions on these two possibilities - or any others? Thanks!
Old Jan 24, 2023 | 11:21 AM
sandymane's Avatar
sandymane
Since the E4OD is controlled by the computer, running diagnostic codes can give you some help in determining the real cause of the harsh shifting.
Regardless of what you find, changing fluid and filter is in your future.
Old Jan 24, 2023 | 11:57 AM
OBS460's Avatar
OBS460
Check all of your brake lights and make sure you don't have a bulb burnt out.
Old Jan 24, 2023 | 12:06 PM
Prototypemech's Avatar
Prototypemech
Check for codes. You'lll probably find the problem. As sandy mentioned, your transmission is computer controlled; you don't have a vacuum line going to your transmission. Is there anything else not working correctly on your truck?
Old Jan 24, 2023 | 12:12 PM
shkawgo47's Avatar
shkawgo47
3rd Gear
Other than the shifting issue, truck is running great. NO check engine light - even momentarily.
Old Jan 24, 2023 | 12:16 PM
sandymane's Avatar
sandymane
Codes can be in the computer without a check engine light.
Old Jan 24, 2023 | 12:25 PM
shkawgo47's Avatar
shkawgo47
3rd Gear
Thanks -- new info for me!!
Old Jan 24, 2023 | 12:32 PM
sandymane's Avatar
sandymane
Key On Engine Off codes should show clues. If you have KOEO codes you need to fix them first before running Engine Running codes. Either test, the truck needs to be at operating temperature to properly test.
Old Feb 2, 2023 | 02:00 PM
Michi65's Avatar
Michi65
1st Gear
One of the potential causes is a bad speed sensor or sensor connection in the rear differential. Without that working right the trans behaves as you describe. It's a $15 part and a 3 minute job so maybe worth trying. At least that was the cause of mine doing much the same and it was cured with a new sensor. I carry a spare now...
Marneaus
1983 - 2012 Ranger & B-Series
Jul 26, 2011 01:56 PM
BEER TIME
Jun 22, 2011 10:30 AM
liftedgrocerygetter
88
Jun 23, 2009 02:20 AM
go-slow
41
Nov 20, 2007 04:54 PM
rbastedo
Aerostar
22
Nov 10, 2004 11:53 AM
