6.2L V8 Discuss the 6.2L V8
catalytic converter
Old Jan 24, 2023 | 09:57 AM
flint9's Avatar
flint9
2nd Gear
catalytic converter
i have a 20 f350 stake body that has p0420 code took it to dealer. they said it needs new catalytic converter 4000.00$. only 63000 miles. dealer said no warranty coverage. warranty only goes to 36000 on f350 converters. anybody have any solutions ?
Old Jan 24, 2023 | 01:21 PM
Split rims's Avatar
Split rims
I would check the coils for corrosion, and the plugs for wear.
Old Jan 24, 2023 | 01:58 PM
flint9's Avatar
flint9
2nd Gear
would that cause a code p0420,
Old Jan 24, 2023 | 05:27 PM
OverheadCram's Avatar
OverheadCram
Id bet your downstream O2 sensor is faulty. Do you have the means to test the sensor yourself, or are you solely reliant on a mechanic?
Old Jan 24, 2023 | 05:28 PM
85e150's Avatar
85e150
What is your GVWR? I can't get into the final link at ford.com/support.
5/50 and 7/70 on expensive emissions components is mentioned, but commercial use and high gvwr are killers for the warranties.
Looks like some things to run down if it's just that code and you haven't been running it with the code for a year:
https://www.autocodes.com/p0420_ford.html
If you do a search by the code, you will get a bunch of hits for Ford.
Old Jan 24, 2023 | 06:23 PM
tjc transport's Avatar
tjc transport
i ain't rite
i paid $1300 for converters for my 2014 from tasca ford 2 years ago. than another $120 for 02 sensors.
Old Feb 3, 2023 | 11:18 PM
Flatbed Ed's Avatar
Flatbed Ed
The price of replacing converters has gone up since a couple of years ago. I had to replace one a few months ago, and it set me back $440 at the local muffler shop. The quality of the converter is nothing like one from Ford but I highly recommend to get an aftermarket one from a muffler shop. It last a long time and it's much cheaper. That code does not necessarily mean however that the converter is bad. A good mechanic can test the converter and tell you if it is good or bad. It may be just a bad O2 sensor
Old Feb 3, 2023 | 11:21 PM
Flatbed Ed's Avatar
Flatbed Ed
Was the truck presenting any symptoms? Or did you just take it to have the code checked out?
claudeyounan
2009 - 2014 F150
17
May 2, 2016 01:41 PM
CNC
Jan 31, 2010 04:50 AM
JRT32615
3.8 & 4.2L V6
Feb 12, 2007 07:16 PM
Racecarhauler
Apr 10, 2006 07:41 AM
W. McCullin
Dec 16, 2003 12:51 PM
