Catalytic Convertor failure
Old Apr 28, 2016 | 04:28 AM
claudeyounan's Avatar
claudeyounan
Hey guys, my 2012 F-150 XLT V8 catalytic converter needs to be replaced.
Could you please advise which brand to use as a replacement? is the Davico Mfg reliable in this case?
Old Apr 28, 2016 | 01:41 PM
unibody62's Avatar
unibody62
Originally Posted by claudeyounan
Hey guys, my 2012 F-150 XLT V8 catalytic converter needs to be replaced. Could you please advise which brand to use as a replacement? is the Davico Mfg reliable in this case?
I can't answer your question about Davico, but I just wants to comment and make sure that it wasn't still under warranty. I think the converter and other parts of the emissions system have an extended warranty, like maybe 8 years/80,000 miles.
Old Apr 28, 2016 | 05:45 PM
claudeyounan
No warranty as i passed 80000 miles already. What about removing the catalytic converter? would the sound be like crap?
Old Apr 29, 2016 | 12:39 AM
brokenleg's Avatar
brokenleg
then the check engine light would be on because it checks to make sure the cats are doing their job.
Old Apr 29, 2016 | 10:26 AM
TCAS007's Avatar
TCAS007
How do you know it needs to be replaced? Check engine light on?
I am afraid the one on my Town Car has a metallic rattle when it is cold. Off topic but does anyone if that is possible?
Old Apr 30, 2016 | 03:36 AM
claudeyounan
The engine light is on and the error given through the scanner is about the cat. The mecanic confirmed that i need to change the cats. The truck power has been diminished as well.
Now what choices do i have? Can i replace the cats with something else? What about hollowing my cats, would my truck sounds like crap?
Old Apr 30, 2016 | 03:56 PM
TCAS007's Avatar
TCAS007
You either replace them with OEM or performance cats from Flowmaster or similar.
Old Apr 30, 2016 | 04:37 PM
claudeyounan
Thanks for the tips but Flowmaster doesn't have the catalytic converter for this truck model (2012). Any other reliable manufacturer?
Old Apr 30, 2016 | 07:56 PM
bmuhlbach's Avatar
bmuhlbach
It would sound like crap if you hollow them out.It would be loader though. I ran a few cars with no mufflers straight off the cats, put x pipes on which take cats off and ran through mufflers also.
Old Apr 30, 2016 | 08:42 PM
Tom's Avatar
Tom
Sounds like some more diagnosis is in order unless you want to be repeating the same repair down the road. Check out this article:
Look upstream for the culprit in a converter failure - Eastern Manufacturing
I wouldn't hollow out the cat. It makes the truck obnoxiously loud, smelly, and is illegal.
Old Apr 30, 2016 | 08:55 PM
85e150's Avatar
85e150
Plus you have sensors after the cat. You would need a tune that simulated the proper signal from the sensors. Otherwise, it is not going to run right.
Old May 1, 2016 | 02:52 AM
claudeyounan
so i think using mufflers with x pipes will solve it but still the engine light will stay on right?
Old May 1, 2016 | 06:13 AM
unibody62's Avatar
unibody62
I would just put a new cat on, don't think aftermarket generic fit is very expensive.
Old May 1, 2016 | 06:18 AM
claudeyounan
yes actually i was willing to do so but dont which cat brand to use. I need a reliable brand do you have any advice?
Old May 1, 2016 | 07:14 AM
Tom's Avatar
Tom
Eastern Catalytic is a good option as well, they're one of the larger aftermarket companies that makes direct-fit cats.
But NONE of them are a good option until you figure out why yours went bad.
